Old 12-23-2009, 10:53 AM   #1
Default what's the trick
whats the trick to making an 8ight t 1.0 a good driving truck ? right now the diffs are 7f/10m/2r, got ride height at 39 and 36mm, got the white springs on front and grey on rear. 2 degrees in on the camber all the way around. and about 2 degrees toe out. running proline holeshots lpr and the aka ibeams. truck drives good but am looking for that "fantastic" set up
any help is appreciated
josh
rookie23 is offline   Reply With Quote
Old 12-23-2009, 02:15 PM   #2
shesha's Avatar
Send a message via MSN to shesha
Josh prior to your posting, consider searching through the threads, use the search feature here to locate the thread and filter it out again once you find the right thread.
For example first search keywords would be your Losi Truggy model "Losi Truggy 1.0"
Then refine down to setup etc etc you would be surprised to how quick you can find the info that way instead of waiting for someone to post back to you something already posted on the official thread.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 12-23-2009, 04:25 PM   #3
scwrod's Avatar
What you are overlooking is their is no one perfect setup. Just like their is no "Best Motor" or "Best Servo"
All tracks are different and you setup a car to handle best on the specific track.
Good rule is, start with a stock setup and go from there.
You have many ways to find the answers
  1. Ask this same question at your local track. Even then you will get different opinions
  2. Learn what each setting does and slowly dial it in.
  3. Download setup sheets and playaround.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 12-23-2009, 04:47 PM   #4
check out losi.com they have a bunch of setups for both the 1.0 and the 2.0.
fievel is offline   Reply With Quote
What's new @ Speed Tech R/C SpeedTech Electric On-Road 3209 01-19-2006 10:00 PM
