Old 12-22-2009, 07:33 PM   #1
Default proline caliber qustion?
i just mounted up some calibers with the green dot inside and i noticed now the treads are going different ways from one side to the other ,what did i do and what does this mean.
bigguyrc8 is offline   Reply With Quote
Old 12-22-2009, 07:35 PM   #2
Trader Rating: 86 (99%+)
Calibers are a directional tire, there desiged to be ran with the tread in the same direction...
WideOpenThrottle RC is offline   Reply With Quote
Old 12-22-2009, 07:45 PM   #3
thanks i kind of figured that one out,(im a jac ass)can u tell me about the directions,one looks like more forward bite,i guess i'll buy 4 more and mount them the same to equal things out
Old 12-22-2009, 07:49 PM   #4
dishsoap's Avatar
I have ran them backwards and my Son has ran them in none matching patters from one side to another.
I didnt see any difference. Keep in mind we race for fun. A pro could probably tell but we couldnt.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 12-22-2009, 08:53 PM   #5
aaron joy's Avatar
Trader Rating: 16 (94%+)
Look for the arrow on the sidewall of the tire. Mount two one way and two the other way.
aaron joy is offline   Reply With Quote
Old 12-22-2009, 09:15 PM   #6
Thats just way to easy.
The Working Man is offline   Reply With Quote
Old 12-22-2009, 09:46 PM   #7
Kent Beal's Avatar
Trader Rating: 65 (100%+)
Glad I read this before putting glue on my truggy tires. Remember when buying them for my buggy that the clerk told me they were directional.
Just forgot because the short coarse tires aren't directional
TLR 22 2.0, 22T 2.0, 22SCT 2.0, SCT-E 2.0, BAJA 5T, 4PK and DX18, Visionaire's, Yak 54 3x, Habu, AS3xtra, 350QX, 130x, 180cfx, 450x, 550x, Nano CPs, Slick 3D, Crack laser and Extra 300x 120cc.
Looked up the word "ninja" in the dictionary yesterday, it said " ninja not found", well played ninjas, well played.
Kent Beal is offline   Reply With Quote
Old 12-23-2009, 03:46 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
When theses tires start to lose traction run them backwards and they will regain traction. Then they will be shot.
Old 12-23-2009, 04:48 AM   #9
mvo
mvo's Avatar
rub your finger against the tread and you will find out.
center and edge in one direction and then in the other direction.
you will notice that in one direction the center will have more grip, and in the other direction the edge will have more grip. So, if you want more forward grip use the direction where the center is most grippy, if you want more sidebite use the direction where the edge is most grippy.
mvo is offline   Reply With Quote
Old 12-23-2009, 12:32 PM   #10
Officespace's Avatar
Just stick the tires/rims you already glued in the oven for 15 minutes at 350 degrees and after that, the CA glue will release and you can separate the rims from the tires. Then just clean any dried CA off the rims and tire walls with denatured alcohol and re-glue them in the correct direction.
I did the same thing when I first bought new Calipers.
Rick Siems
TLR 8ight 3.0 Buggy/Samurai .21 & OS .19 Speed Engines- AKA/James Tires
TLR 8ight 3.0 Truggy/OS .21XZ-B Speed Spec II- AKA/James Tires
Dialed R/C Hobbies, Absolute Hobbyz, JConcepts, Airtronics, Protek
Officespace is offline   Reply With Quote
Old 12-23-2009, 04:32 PM   #11
Trader Rating: 24 (100%+)
Or dump a 16oz of Acetone in a bucket and put something in there to elevate the tires from touching the acetone. Let them sit for a few days and they will just fall off. If there is still glue on the rim, put the rims only in the bucket for a few more days and the glue will fall off.
JodyJ is offline   Reply With Quote
Old 12-23-2009, 05:46 PM   #12
Integra's Avatar
Caliber's...not Caliper's.
Originally Posted by JodyJ View Post
Or dump a 16oz of Acetone in a bucket and put something in there to elevate the tires from touching the wheels. Let them sit for a few days and they will just fall off. If there is still glue on the rim, put the rims only in the bucket for a few more days and the glue will fall off.
X2...Best method around no doubt.
tire foam qustion bigguyrc8 Nitro Off-Road 21 12-19-2009 06:33 AM
