Old 12-21-2009, 01:43 AM   #1
Default sealing carb of nitro engine
HI guys,
I want to seal the carb off my caster mk 21. do i need to remove the carb or can I apply a long bead around the carb.
I have removed carb before . not only was it a nightmare. but i found the sealant getting scrapped away when i force the carb back inside
muaythai is offline   Reply With Quote
Old 12-21-2009, 01:50 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
you can do it from the outside with the Lucky 7/Racers Edge type, just use a small flat head to spread it
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 12-21-2009, 02:04 AM   #3
Default thanks!
thanks
Old 12-21-2009, 02:53 AM   #4
yuppi1's Avatar
i would just bring it out enough to get the bead just inside so when it is fully in it will seal properly
yuppi1 is offline   Reply With Quote
Old 12-21-2009, 05:24 AM   #5
j_blaze14's Avatar
Trader Rating: 34 (100%+)
Originally Posted by muaythai View Post
HI guys,
some will come off, but the right amount stays. is the carb having issues? if not i would leave it alone if you are not sure how to do it.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 12-21-2009, 05:48 AM   #6
Default sealing
no. well not that i noticed. its just a few caster has had air leaks. just seen another yesterday at a track. just like mine, the bottom end was richen till the screw looked like it was about to come out , but the engine still sounded too lean when accelerating.
the poor chap DNF with a engine about 300f!
mine went the same way a few months back. i had a leak in my exhasut gasket but i think there was a leak some else since it got so hot
Old 12-21-2009, 06:04 AM   #7
j_blaze14's Avatar
sounds like a front bearing leak or maybe a kinked line? seal it up to be safe, i have 4 grenades and the only issues i ever had were cracked cases... oh oh check for that. the top is good but the idle is very inconsistent, it goes from too lean to good to too rich.
Old 12-21-2009, 06:04 AM   #8
j_blaze14's Avatar
double post...
Old 12-21-2009, 08:31 AM   #9
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Lucky7RC Engine Sealant should be used externally only. Use it like a coating, not like a gasket.
http://www.lucky7rc.com/product_info...roducts_id=247
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 12-21-2009, 08:58 AM   #10
Trader Rating: 36 (100%+)
L7 FTW!
NitroOB4You is offline   Reply With Quote
REEDY .21 Nitro Engine Kevin Boyle Offroad Nitro Engine Forum 1359 10-08-2014 01:19 PM
Nitro TC3 thamjk Malaysian R/C Racers 5356 01-04-2009 07:18 PM
Nitro fuel -which brand and why? Morpheus2be Malaysian R/C Racers 145 08-22-2003 01:30 AM
