Old 12-20-2009, 12:33 PM   #1
Angry MY RC nitro car cuts out when throttle is applied
hello everyone
i have a kyosho inferno mp-6 sports which is a nitro buggy
the engine in it is a GS21R and i am having a few problems with it
originally it was working fine and then the thread on the needle valve died so i bought another 1 from kyosho same model and fitted it and turned it 2 and a half turns (the correct amount of turns needed for the engine to run properly)
it then kept starting for like 10 seconds and then cutting out my dad had a look at it and adjusted the air/fuel mixture adjustment screw now it ticks over fine and will run on tick over until it runs out of fuel but when ever throttle is pressed down and the hole opens it cuts out??
very strange
can anyone help me with this problem?
thanks
tom
tom widdowson is offline   Reply With Quote
Old 12-20-2009, 01:05 PM   #2
I'm fairly new to nitro, but I was having the same problem. It's called a flame-out. I believe, if the mixture is too rich slightly, the carb builds up with fuel while the car is sitting still, then when you apply the gas, it rushes all the fuel into the motor, and it basically suffocates the motor, causing it to stall or "flame" out. Keep high revving the motor a lot before you run to "clean" it out, and maybe lean out your mixture a bit. Like I said, I'm fairly new to nitro, but it sounds like the problem I was having.
monster95 is offline   Reply With Quote
Old 12-20-2009, 01:41 PM   #3
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
that does sound like a rich bottom end needle/ low idle setting.
read this
it'll help you out a bunch
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
Old 12-26-2009, 02:29 PM   #4
Smile thank you
thanks guys for all your responses and so quickly
me and my dad have fixed the problem thanks to your help and the engine instruction manual
turns out that we where running it way to rich as we could see by the liquid form fuel which was coming out of the egsaust so we fiddled around with the carb to get it just right and now it will throttle from tick over to fully open with out even stuttering
i shall try it out on the skiddy roads tomorrow and tell you what happened
thanks everyone
Old 12-26-2009, 02:42 PM   #5
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
just remember to tune it to how it sounds/runs. dont get married to a temp gun.
i suggest the trinity 'nitro tuning' book to help you in understanding your engine and making your rc experience in the future a fun 1 for yourself and ur dad.
this coming from an 'electric guy'.
R
UltegraSTI is offline   Reply With Quote
Tags
inferno mp-6 cuts out
