Old 12-20-2009, 01:10 AM   #1
yuppi1's Avatar
Default ENGINE PROBLEM QUESTION?
When i start my team infinity .27 engine it will run while the glow igniter is on but as soon as i take it off it cuts out?
what could cause this? i tried a new glow plug and it did the same thing
cheers
yuppi1 is offline   Reply With Quote
Old 12-20-2009, 01:20 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
If you realy did try a new plug then there are some possible issues:
- to low compression (P/S set end of life)
- to cold plug, try a hotter version
- to rich setting, try to lean it.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 12-20-2009, 01:31 AM   #3
yuppi1's Avatar
cheers yeah new plug straight out of pack. thanks for that
Old 12-20-2009, 07:49 AM   #4
Default re
leave the ignitor on it for a bit rev a little get it warmed up if it is rich the base will load up with fuel and kill the spark I see this a lot it wont hurt to leave the ignitor on to get the engine warmed up
toofless is offline   Reply With Quote
Old 12-23-2009, 01:36 AM   #5
yuppi1's Avatar
still cant get it to run! will still cut out as soon as i take the igniter off
could the fuel be an issue?
it is about a month old?
cheers
Old 12-23-2009, 07:40 AM   #6
cheers
Sounds rich check tuning bible top of forums
153stars is offline   Reply With Quote
Another engine problem thread! Toltol Nitro Off-Road 9 06-18-2008 05:38 AM
Sirio Engine needle question, is it faulty? no1stunna Nitro On-Road 10 04-14-2003 03:18 PM
