LRP 28 SPEC 3 BLANK BACKPLATE? >
Old 12-16-2009, 01:36 AM
Breno25's Avatar
Trader Rating: 37 (100%+)
Default LRP 28 SPEC 3 BLANK BACKPLATE?
Has anyone tried to fit a blank bump starter back plate to the pullstart lrp 28? The crankpin hits the lrp blank plate. What plate can be used??
Breno25 is offline
Old 12-16-2009, 08:12 AM
You can either grind off the pull start pin, or replace the crank with the non-pull version.
Grinding the pin off isn't hard to do, done it several times myself.
McFly505 is offline
Old 12-16-2009, 01:12 PM
mechanic77's Avatar
Just try the Dynamite backplate (part#DYN0960). It has a groove cut in it to clear the pin on the crankshaft, no modification necessary
mechanic77 is offline
