Old 12-15-2009, 01:08 PM   #1
Default erratic idle losi 454
i am having a problem setting idle after running the truck i will come to a stop and it will return to idle if i wait 3 or 4 seconds the idle will go high almost to the point will the truck will start to move on its own is this a low/high speed needle issue i checked the linkage for binding (pushing slide by hand) and doesnt seem to be the issue just sealed carb 2 days ago any suggestions are appreciated truck was running in the 230-250 range and the temp outside is like 20 very cold warmed motor up to 200 with heat gun in garage
cobranick is offline   Reply With Quote
Old 12-15-2009, 01:33 PM   #2
aaron joy's Avatar
Trader Rating: 16 (94%+)
Sounds like your low-end is too lean. I would richen it up, you may have to raise your idle after richen the bottom end.
aaron joy is offline   Reply With Quote
Old 12-15-2009, 01:41 PM   #3
ok thanks ill give that a try
Old 12-15-2009, 06:42 PM   #4
hdcruzer's Avatar
Typical 454, Thats why mine is in a box and I run a werks B5 now............
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 12-15-2009, 07:58 PM   #5
+1 common with the 454
bigde2001 is offline   Reply With Quote
Old 12-15-2009, 09:21 PM   #6
have you considered a possible air leak at your carb
rc_racer1 is offline   Reply With Quote
