Old 12-14-2009, 06:25 PM   #1
Beadlock's Avatar
Trader Rating: 4 (83%+)
Default Is this engine too much?
http://www3.towerhobbies.com/cgi-bin...?&I=LXLGH6&P=0
Is this engine too much for a D8? Normally I wouldn't consider a .30 but things are tight at the moment and the price is right being a 3 pay. Will it work?
Beadlock is offline   Reply With Quote
Old 12-14-2009, 06:27 PM   #2
did you check out the alpha engines? they are around the same price and would give you more performance and better fuel economy.
www.rc-international-speedways.com
Associated B4 with novak GTB and Velociti 7.5
Corally RDX with tekin r1 and redline 13.5
Preston777 is offline   Reply With Quote
Old 12-14-2009, 06:28 PM   #3
Adro's Avatar
It should fit but it a hell of alot of overkill, your runtimes will be low because it will use alot more fuel and you wont be able to race it at sanctioned events (only club meets)
Adro is offline   Reply With Quote
Old 12-14-2009, 06:30 PM   #4
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
This would be a better suited race engine for that car at the same price and has easy pay as well.
http://www3.towerhobbies.com/cgi-bin...?&I=LXTBR9&P=0
awdcameolsx is offline   Reply With Quote
Old 12-14-2009, 06:32 PM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Do you want to race, or bash? It isn't race legal... .21 limit for buggy.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-14-2009, 06:35 PM   #6
allan42r's Avatar
werks b5. $200,more run time,easier to drive, more rpms/ top end. 30 is a big block, low end not as fast on top end. and thru pay pal at a main its 90 days no payments
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 12-14-2009, 06:35 PM   #7
DOMIT's Avatar
Can you put 2 payments together?
http://www.amainhobbies.com/product_...-Standard-Plug
http://www.amainhobbies.com/product_...d-Plug-08-Spec
Either of those would be a better engine, at $150 for either.
Old 12-14-2009, 06:55 PM   #8
Beadlock's Avatar
Yeah, I figured it was overkill. I also completely forgot it might not being legal, as I am going to club race this year. I will double check the rules. I have some time before I have to throw down on one, but would like to keep it around $200.
Thanks very much for the suggestions..Any thoughts on the Jammin engines?
Old 12-14-2009, 06:56 PM   #9
Trader Rating: 47 (100%+)
You may want to check this engine out also.
A great engine at a great price.
http://www.nitrohouse.com/catalog/pr...ducts_id=21551
rageworks is offline   Reply With Quote
Old 12-14-2009, 06:57 PM   #10
chris c's Avatar
Trader Rating: 60 (100%+)
Go with the OD ss.21 it is insane!!
If you can make it I can break it
chris c is offline   Reply With Quote
Old 12-14-2009, 07:00 PM   #11
DOMIT's Avatar
The Jammin JPX21 is a good engine.
The new ALPHA engines are great, and for a great price. $199 for the 5 port, $209 for either of the 5+2 ports from RC Pro Products. The 5 port is probably plenty.
Also the Werks B5, as mentioned.
Once you hit that $200 mark there are a lot of good engines starting to become available to you.
Stick with a .21 not only to be legal but for better runtimes (fuel mileage) when you race. (It reduces pit stops, so overall makes you faster.)
Not only do I not know anyone running a .30 in a buggy... I don't know hardly anyone running more than a .21 in a truggy. Virtually all the fastest pros run .21 in truggy.
Old 12-14-2009, 07:07 PM   #12
DOMIT's Avatar
p.s. I run the Novarossi I sent you the link to... but modded. Not enough for the truck in my opinion, but would be OK in buggy on shorter tracks.
I'm getting an Alpha.
'nuff said.
Old 12-14-2009, 10:43 PM   #13
Suspended
Honestly if u wanna be smart give yourself a week of looking Rctech forsale threads and buy either a nib engine or one that has under a gallon of fuel ran thrue it and expect to pay almost nothing for it! I got a ninja that had half a gallon on it that's lasted me almost 7 gallons now I got it for 200 bucks shipped that's for a 350$ engine also my best deal I got was a ninja(edit O.S. Not ninja) 09 vspec with 2060 pipe that was basically brand new just 2 tanks of break in for 250, that's a pipe/engine combo!! Just go in there n keep n eye out i'm even selling an engine that's usually 360 that's got a half gal ran thrue it for 150 shipped n a us spec with 3 quarts and brand new ceramics just installed for 165$ u gotta look for the deals cause people are selling stuff cheap right now!
Mxracer61/801 is offline   Reply With Quote
Old 12-15-2009, 08:25 AM   #14
Beadlock's Avatar
You guys rock...thanks for all your help
Old 12-15-2009, 10:11 AM   #15
The new GX series Go engines are also right there at the $200.00 price range. They are the only engine in that range that comes with a coated crank, a full set of carb inserts, and a extra con rod.
I use them and have got over 5 gallons on both my 5 and 7 ports and they are both still going strong.
Like others have said I would read the threads so you can make an informed decision.
matrixmike28 is offline   Reply With Quote
Is modified engine any better than stock one? Kevin Kim Nitro Off-Road 34 10-08-2007 12:53 AM
So much for buying this engine!!! Nova 353 MRX4-R03 Onroad Nitro Engine Zone 48 04-24-2007 07:04 AM
Nitro RS4 SS not likin me too much SpeedDemon911 Nitro On-Road 80 04-17-2007 08:06 PM
