Old 12-15-2009, 11:29 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by dnebout View Post
No feather finger here. My car went 13 minutes (155cc) I wrecked 3 times on that tank so if you subtract 30 seconds (conservative estimate) for each wreck, I ran for 11.5 minutes. Then I handed it to one of the pro guys and he leaned a 1/2 turn. I haven't timed it after he tuned it, but it has to be better.
small tracks u will get better runtimes Dave
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-16-2009, 07:44 AM   #17
dnebout's Avatar
Trader Rating: 32 (100%+)
I do run on a small track. Maybe that's why I'm so amased when people get excited over 10 minutes of run time.
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Old 12-16-2009, 09:04 AM   #18
houston's Avatar
My point exactly bro
Its a little different when you get to a larger layout , more fuel flowing through the engine reaching higher rpm's and staying on the pipe . Runtimes decrease quite a bit , that's where the 6mm insert venturi and all that stuff comes into effect .
Happy motorin',
Monty
Old 12-16-2009, 09:23 AM   #19
dnebout's Avatar
Happy motorin',
Monty
ok we haven't talked about this it all. Should I run a bigger venturi. I have a 70 foot straight, a bunch of turns and I think 9 or 10 jumps back to back down the back straight. I want to tripple one jump, but can't get enough power to do it. I have the pipe combo I want, but what venturi should I use. Right now I'm running the 6mm venturi. I usually end up in the B Main, which runs 20 minutes. I end up fueling least once.
Blackjack 26
Old 12-16-2009, 10:26 AM   #20
houston's Avatar
Ya you can probably use the 8mm and still make 10min on that size of track .
There is alooooootttttt of info in these threads if you take the time to read em dave.
You should work hard to get in the A !!!
