Old 12-13-2009, 05:26 PM   #1
rccrazy_racer's Avatar
Trader Rating: 6 (80%+)
Default Buggy engine mount question
I'm not a new-b, but I'm scratchin' my head on this one! I just picked up a Hyper 8 Pro buggy with the Hobao engine mounts and decided to drop in an engine. As I put the engine onto the mounts to see how it lined up...I noticed the clutch bell was about 1/4" or more behind the spur gear! The engine mounts can move from side to side, but there is not any adjustments for front to rear movement. Am I totally missing something? The engine is from a Savage...the 4.1 (.25) and I also tried an OS 30 just for fitting purposes. Both engines have the same problem. Any insight from buggy racers/owners would be appreciated.
rccrazy_racer is offline   Reply With Quote
Old 12-13-2009, 07:18 PM   #2
Integra's Avatar
HPI flywheel's are really short and dont have any step built in like most 1/8 buggy truggy clutch's do....so it will sit a lot closer to the motor VS a normal Flywheel and will cause what you are describing....you need a new clutch basically.
Old 12-13-2009, 07:24 PM   #3
Default Thanks!
I thought about that, but wasn't sure. Can I just use a different flywheel collar? Would that move it out or just a new flywheel altogether with a matching collar? I appreciate the insight!
Old 12-13-2009, 07:34 PM   #4
Integra's Avatar
you can just shim the back side of the collet and bring the whole assembly forward....but from knowing how crappy the stock savage clutch's are is why i recommended you get a proper 1/8 bug/trug clutch set-up....you can use most any collet with any flywheel with A very Few exception's.
Old 12-13-2009, 07:35 PM   #5
Trader Rating: 47 (100%+)
Make sure you get a flywheel nut to match
the flywheel. That way the clutch springs
will fit properly.
rageworks is offline   Reply With Quote
Tamiya TRF 801X 1/8 Buggy! bola Nitro Off-Road 2517 02-13-2017 09:11 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
FS: King Headz EZ Change Extended Engine Mount for Losi 1.0/2.0 Buggy/Truggy Garet Jax R/C Items: For Sale/Trade 14 08-19-2009 11:45 AM
D21B Buggy Engine dino.tw Onroad Nitro Engine Zone 149 07-19-2006 05:08 AM
