M2C Racing clutch problems fixed for the RC8-RC8B
Attention all RC8-and RC8B racers,
There has been a problem with the M2C racing clutch for the RC8B nitro buggy, due to the brake hitting the flywheel and causing the motor to be shut down while racing, with the old style system that was first in production. M2C Racing has redesigned the system now with a variable weighted flywheel that works flawlessly. With a minor adjustment made to the brake gap, which is explained in the instruction sheet you will be on your way to running this awesome clutch system manufactured from M2C Racing!!! Note: With this adjustment made to the braking system you will be able to lower your EPA setting for your brakes which will help in not over working your throttle servo!!!! |
