Old 12-12-2009, 04:08 PM   #1
Default Set-up books
Who has setup books that they take to the track. For those that do what do you have in them? Thanks for the info
SMOKESHOW86 is offline   Reply With Quote
Old 12-12-2009, 04:33 PM   #2
Trader Rating: 61 (100%+)
best thing to do is get a 3 ring binder and get a big pack of those plastic sleeves ..they come in a pack of 100 from like office depot ...print your stuff out put it in the sleeves and your golden
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 12-12-2009, 05:00 PM   #3
Couple folded up setup sheets with remarks at the bottom in my tool box.
The car I run now dont seem to need much in the way of setup change no matter where I drive.
Diff oil change,small shock oil wt change,& small front/rear camber change is usually all, once in a great while springs but the stuff changed from the std setup I settled on is for that dirt on that day.
I am by no means a real fast guy just a mid-top sportsman,but I have come to the conclusion that big setup changes often are more detrimental than just zeroing in on a good all round setup & getting used to it with minor changes to suit that day if you need to compenste.
May be car dependent though as the last couple car saw big changes often & I never could get to a comfortable place with them.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 12-12-2009, 05:35 PM   #4
dnebout's Avatar
Trader Rating: 32 (100%+)
I depend on my Losi manual. It's all in there. Camber effects, Toe effect , oil weight, droop, ect. I also printed a quick tuning guide that i found. I carry a black sharpie a pad and a pen. I write down parts that I need to order. try different setups and mark the final setups on a blank Losi Set-up sheet. I'm very new but am totally hooked. I did this with my full sized rock crawler and worked good for me, so I use the same system on this new toy.
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Track Design: Books, Articles, Forum? TerraX Nitro On-Road 61 07-05-2005 12:59 AM
Set-up boards axel Electric On-Road 31 06-29-2005 08:51 AM
driving books/websites? snopro31 Electric On-Road 18 08-25-2004 04:00 PM
