Old 12-10-2009, 08:44 PM   #1
Default Why is my rossi running so hot?
I have a rossi .28 in a truggy and when im running it it will get pretty hot when im on the throttle a lot and bring it right in a take the temp. It has read over 300 a few times. When the truck is just driving around at low speeds and never really getting up to top speed in doesnt seem to do this.
Now it seems like a classic low speed is rich to fix lean high speed but there is a pretty good amount of smoke coming out.
It's not the clutch or drive train since it's all free spinning and the clutch is brand new.
Could it still be the low speed rich high speed lean thing?
The truck never stays at those hot temps, it goes right back down after idling for 10 secs or so.
Preston777 is offline   Reply With Quote
Old 12-10-2009, 08:49 PM   #2
tc5 man's Avatar
to me that defiely sounds like a air leak somewhere my nova .21 bf was
doing the same thing.
Old 12-10-2009, 08:53 PM   #3
yeah i thought that might be what is was but i sealed the engine when i got it so i have no idea. I took it out and did the soap and water test to check and i couldnt see any leaks. Unless it's the front bearing. It doesnt leak from what i could tell just a little nitro sometimes but i havent seen an engine that doesnt do that.
Old 12-10-2009, 08:54 PM   #4
tc5 man's Avatar
what about the carberator
Old 12-10-2009, 08:55 PM   #5
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
Is it preforming well, with no bogging, flat spotting, or high idling off of the jumps ? You say you have smoke, and your drivetrain is freed up, so I'm guessing that maybe your temp gun is the culprit.
Take the head off the engine, and check to see if there any pitting on the head button and/or piston. If there is, then you've ran it too lean a few times.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 12-10-2009, 09:01 PM   #6
Now that i think about it my temp gun might be wrong. and yes i the carb is sealed as well tc5. I will go buy a new temp gun and see what it has to say. I'll check the head button and piston as well.
Old 12-10-2009, 09:03 PM   #7
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Both good things to look for, temp with a selecton of guns next time out..... the plug will distort and tell you its detonating before the button or piston gets pitted..... take a good look at the plug, with a magnifying gass if you can get one.
Other than that I would say richen that beast up on top.... if the idles wants to drop, lean the bottom out alittle. Basically run the top just a tad richer than top speed achieved..... If your straight at the track is super long the engine can literally be running out of fuel being on the high side needle for so long and temps will rise very fast in that condition. Smoke isn't thedetermining factor for me really.... I can make an engine bellow smoke and run 300'... too rich will cause heat also .28s arent exactly RPM monsters, the piston, rod and cranks in them are alot heavier than .21s so typically a .28 will turn 5,000+ less RPM and usually need a taller clutch bell to achieve the same speed.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 12-10-2009, 09:04 PM   #8
imaxx21's Avatar
Send a message via AIM to imaxx21
put a drop of water on the head if it doesnt sizzle off instantly its not that hot...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 12-10-2009, 09:05 PM   #9
Pick up an Odonnell gun..... been using mine for about 2 yrs without any issues and it within a few degrees of every excergen I've tested it against
Old 12-10-2009, 09:18 PM   #10
here are the pics of the piston head and the button. my gun read over 325 today when i was trying to figure out what was wrong and that doesnt seem possible with the plug still in tact.
Why is my rossi running so hot?-dsc00695.jpg   Why is my rossi running so hot?-dsc00697.jpg
Old 12-10-2009, 09:53 PM   #11
That plug doesnt look good at all..... and the carbon trail to the exhaust port on the piston tells me its been run pretty lean. I think your gun is right
Anytime the glow element (the coil) is dull, grey or white basically anything but shiny its a bad thing
You running odonnell fuel by chance?
Old 12-10-2009, 09:59 PM   #12
i did run maybe 2 or 3 tanks of it through it but i am running sidewinder now. Does that carbon trail mean the motor is going to be bad? or will it be okay if i richen things up and get it tuned right.
Old 12-10-2009, 10:13 PM   #13
what plugs would you recommend running in it? i have been using medium O.S. plugs. something that would be better?
Old 12-10-2009, 10:19 PM   #14
It looks like an odonnell engine by the color of everything, not a bad thing
It'll be fine... throw that plug at the guy that sold it to you and get a longer plug.... take a close look at how far the plug goes into the combustion chamber.... the OS plugs are shorter than regular plugs. Thats a contributing factor to your tuning issues, your essentially running a super cold plug. OS plugs typically only fit in OS engines. Pick up some regular Odonnell 97's and tune those in, start from scratch. Richen the HSN 1/2 turn and start over
Old 12-10-2009, 10:25 PM   #15
yeah i thought it didnt look right sitting in there haha. Im just going to go back to the factory settings and redo it. I am going to pick up a new temp gun though. I have a duratrax one and i dont like it at all. Are the 97's a turbo only plug? it's a standard plug engine.
STS engines sparksy Onroad Nitro Engine Zone 2774 02-03-2013 06:05 AM
Axe Rossi Mamba sport10 Nitro Off-Road 110 01-30-2010 09:12 PM
RC car- True Turbocharger. 1BadTransam Nitro On-Road 144 08-02-2009 11:17 PM
Engine seems to run hot... Yet there is nice trails of smoke. mini696 Nitro Off-Road 25 11-04-2008 02:26 AM
AXE ROSSI ENGINES??? EVIL-ET Onroad Nitro Engine Zone 15 12-13-2007 09:43 PM
STS D21T & D21B porter Electric Off-Road 31 01-16-2007 12:30 AM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 07:49 AM
