Old 12-10-2009, 02:04 PM   #1
Billetboy's Avatar
Trader Rating: 49 (100%+)
Default Flame out on hard landing?
Hello,
I am new to nitro and have been running a Novarossi +4 for 3 weeks now. The +4 has run perfect. I usually have to shut the engine off. Never flames out or dies.
Last night at a club race, the engine died when I let a friend drive it and he overshot the triple and landed hard in the flat. I would never thought twice about it except in the Main I was hit hard in the side by another buggy and the motor stopped again.
Would you consider this a flame out? Or will these motors die from hard impacts?
Thx in advance!
***Losi 8T 2.0/O.S. Speed II/2060/Hitec 7945***
***Agama/Orion MTE 5 port/2013/Hitec 7945***
***Losi 8/Orion CRF Alpha MTE/2013/Hitec 7945***
Billetboy is offline   Reply With Quote
Old 12-10-2009, 02:07 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Billetboy View Post
Hello,
Thx in advance!
did you check your clutch ?
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-10-2009, 02:21 PM   #3
Billetboy's Avatar
Yes, I had just put a new flywheel on it last night because one of the pins on the associated clutch came out and rubbed on the inside of the clutch bell. So it was a brand new clutch set up last night.
Old 12-10-2009, 02:27 PM   #4
Tony Newland's Avatar
Trader Rating: 50 (100%+)
plug probably
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 12-10-2009, 02:35 PM   #5
Maximo's Avatar
is it possible your flywheel is grounding out when it lands ?
Maximo is offline   Reply With Quote
Old 12-10-2009, 02:39 PM   #6
RBMike's Avatar
+1, Most likely cause.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 12-10-2009, 02:44 PM   #7
JBURCH's Avatar
It is possible but wouldnt that have to be a perfect hit on like a rock or something protruding up from the track since the flywheel is above the very bottom of the chassis. I know my flywheel does not stick down below the chassis. But it could happen surprise it has not with my luck lol
JBURCH is offline   Reply With Quote
Old 12-10-2009, 02:53 PM   #8
Billetboy's Avatar
Yes! Thanks Maximo, I didnt think of that, but I only have 1mm of clearance between the clutch bell and spur gear. I was told that was normal on the RC8. I can actually flex the chassis and make it touch. Duh! Now I know that is what happened. I guess I am ordering the King Headz RC8 motor mount with the 1.5mm setback. That should solve the problem.
Thanks guys!
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 11:33 AM
Rain City rcracerric Northwest Racers 6484 04-30-2011 12:01 PM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
