Old 12-10-2009, 01:00 PM   #1
Marcus Falconie's Avatar
Default Is it the motor or the carb that makes a good motor
Over the years of racing I have always come back to one thing Novarossi carbs. I have run every thing and I always put a Novarossi carb on the motor. I have a Werks B3 with a Nova carb, a OPS SFV21B with a Nova carb, and a Novarossi with a Nova carb and they all run the same, GREAT. I cant say they ran that way with the stock carbs. I just broke in a new motor today and before I even started the motor I put a Novarossi carb on it and every thin went great. How many of you guys run Nova carbs on a non Nova motor with good luck?
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 12-10-2009, 01:16 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
i have seen many who do the same
i have also seen many who put os carbs on their engines
it is hard to get a better design than the novarossi carb (short needle design)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-10-2009, 01:31 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
Basically, OS and Nova have both figured out something in the carb department that just plain works better than everyone else. The only other carb I really like is the orange one that came with a Star made RB Xenon Alpha onroad motor. Basically it's a billet made clone of the Nova cast aluminum carb. I think some of the other Star (Sirio) based motors are coming with a non-anodized version of that carb now.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-10-2009, 01:35 PM   #4
SteveP's Avatar
I would have to agree with Sean. The carb is such an important aspect of the engine that most engine guys keep a box of primo carbs that get swapped from one engine to another. The rest of the engine is critically important too, but only once you're sure that the carb is spot on.
SteveP is offline   Reply With Quote
Old 12-10-2009, 01:41 PM   #5
wingracer's Avatar
Yep, I do that. One of my onroad motors (I actually don't know for sure which motor it's on) has the carb from an old 2000 era RB C4 on it. That thing just runs right no matter what I do. Oddly enough, that is actually the only Nova carb I have ever had a problem with. The HSN seals were junk brand new. Replaced it with a double o-ring RB needle and it's been fool-proof ever since.
Team Shepherd USA
Old 12-10-2009, 02:08 PM   #6
SteveP's Avatar
Yeah, I noticed for a period of time that Novarossi was over-stuffing their O-rings (much too tight) and it was causing them to be cut in the assembly process. This combined with the fact that the assembly lube would dry out and make the needles REALLY hard to adjust and cause the O-rings to tear. Like you, once I replaced the O-rings and was more careful that their installed properly, but they turned out to be pretty good carbs.
BTW - did you notice that the assembly lube during that time period would eventually cause corrosion around the needles?
Old 12-10-2009, 02:23 PM   #7
Default carbs
At this time I run a Fusion Mod Werks B3 with a old Nova P5 carb in Buggy and a Vega Hurricane Speed www.spmracingparts.com .21 in Truggy with a +4 carb. The Vega motor is made by a company in Italy called Cipola Motori the oldest italian micro motor company out there, and with the Nova carb it runs great!!!!!with the carb it came with, not so much. It killed the motor in the US but the motor itself with a new carb is great.
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
Old 12-10-2009, 02:34 PM   #8
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Most of the time people replace carbs (not referring to you specifically) is because the one they install has been tuned previously.... the one that comes with it hasnt.
I personally hate Nova carbs because of the short neede design (relax Monty haha) I like the smoother delivery of a long needle (OS, Sirio, CMB flat slide ohhh ya betcha never seen one of those) mileage it better and the tune isnt only limited to idle and WOT mixture...... my Vspecs blow fins off alot of high dollar engines with a 6mm restrictor and get 9 mins + anywhere I've ever raced. Stepping up to Speed IIs next year so I might have to throw in a 5.5 and get 11 mins + with the rediculous amount of power they make.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 12-10-2009, 02:42 PM   #9
Default motor
I guess I like the short needle design because they work great for me. As far as Sirio carbs go Junk imo. CMB ran them in boats for the last 10 years and that is a motor made to run WO. Rich Reed was the importer of the CMB RS Pro and Andy Brown did the CMB Mac 21 that I ran for a few years. Like I said I have run them all and Nova and OS carbs are all I will use.
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
Old 12-10-2009, 02:49 PM   #10
wingracer's Avatar
Yeah, the short needle can be a little tricky to get right if you do a lot of part throttle driving but it can be done.
Yes, I have seen the flat slide carb. Better yet, I think I still have an old Picco torque carb around here somewhere
Team Shepherd USA
Old 12-10-2009, 02:51 PM   #11
wingracer's Avatar
Agree completely. Except for like I said earlier. The new billet ones that are really just Nova clones seem to work very well. At least the one I have does.
Team Shepherd USA
Old 12-10-2009, 03:58 PM   #12
Sounds like we're from the same mold then.... I ran some of Rich's motors back in the day, as well as Andys stuff (even the buggy motor he did for awhile back around 06) He's actually making some hardware for my .12 rigger right now, I still run boats from time to time.... lol small R/C world. IMO boats teach you more about engines and tuning than cars ever will..... much more technical on tune and setup.
haha I hated those picco "torque" carbs...... ugh, I had a Lamberto modded XS220 that he swapped out to something different Picco had years ago. That carb was solid but the torque's I couldnt ever get them sealed up and run with any consistency.
The thing that surprises me is how many carbs are designed for heat soak.... when IMO that is most of the tuning issues people have, not letting the engine fully warm up before wearing theyre screwdriver out. Heat soak designs are more critical of this than say an OS...... next time yur at the track run your car for a tank and fee the temp (or use your gun) on the carb at the body just below the HSN.... then go temp an OS.... the OS will be ithin a few degrees every single run.... a heat soak type will vary up to 50 degrees. I think thats what make OS a much more consistent carb to tune.
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
WHAT RED PUTTY IS USED IN THE CRANK SHAFTS MRX4-R03 Onroad Nitro Engine Zone 88 01-27-2010 01:11 PM
MGT 4.6 or Savage 4.6 rgrassey@me.com Monster Trucks 29 11-07-2009 04:29 PM
standard Vspec or Ninja JX B01A? gameholic2 Nitro Off-Road 19 03-26-2009 02:43 PM
Trouble Starting a Kyosho QRC RAM ShakataGaNai Monster Trucks 7 04-18-2007 09:13 PM
motor saver or "killer" t4usee Electric Off-Road 13 06-12-2006 08:12 PM
