Old 12-09-2009, 08:13 PM   #16
slumlord's Avatar
2 v-specs.
Is it just me or is there a pattern forming here?
Jay Stuart #66
slumlord is offline   Reply With Quote
Old 12-09-2009, 08:14 PM   #17
Integra's Avatar
Originally Posted by RobS View Post
My GO tech 7 port. Was running on the track in practice by myself when I thought I flammed out. Brought it back to the box, and snap! Right in half.
Up until then it ran awesome. Not quite sure why it happened... Totally awesome none the less!
wow.....That's Impressive.
Old 12-09-2009, 08:20 PM   #18
Integra's Avatar
Originally Posted by slumlord View Post
2 v-specs.
this hobby is abusive on gear...there's no pattern..it's those 1 in a million hits that cause catastrophic failure and there's not much you could have done to prevent it.
Old 12-09-2009, 09:53 PM   #19
tom2tone's Avatar
Trader Rating: 98 (100%+)
another v-spec here... ran about 4 gallons through on my mugen 5t then put it on my losi 8b. Got about 2 races days and it's cracked
Since we are on the subject.... this is my first nitro motor. Should I replace the crankcase or just get a new motor?
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 12-09-2009, 10:01 PM   #20
tc5 man's Avatar
man thats crazy i guess i been lucky or something my engines never cracked weird man.
Old 12-09-2009, 10:23 PM   #21
Maximo's Avatar
2 v-specs.
It seems the cases that are injection molded are more prone to cracking... most current brands use injection molding to make their cases...a few companies still use cast cases...from everything i understand a cast case is more durable then a injection molded case..... FYI Picco uses a cast case and I have never yet heard of a Picco cracking a case like this, not saying it hasn't happened, just that I have never seen or heard of it...
Maximo is offline   Reply With Quote
Old 12-09-2009, 10:40 PM   #22
houston's Avatar
Trader Rating: 91 (100%+)
quality materials
holy smokes !!!! haven't seen one like that before
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-09-2009, 10:54 PM   #23
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by houston View Post
quality materials
I have seen several onroad motors do that exact same thing, and yes they were Novas. Not really applicable to offroad though. In those cases, the breaks were caused by cars getting flipped upside down and sliding backwards into a wall. The roll bar doesn't protect the back of the motor so when the rear of the body goes over the wall, the head takes a big hit and snap.
I also saw one do this from a rod failure.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-09-2009, 11:49 PM   #24
SteveP's Avatar
Aluminum can't be injection molded. There are various methods of casting, but most engineblocks are made using an investment or possibly a sand casting process. Perhaps some old engine blocks were made using a die cast method, but it's very crude and the intricate shapes that you see in modern engines are not possible with die casting. They would require a lot of machining to finish the block, which is cost prohibitive. Most established engine manufacturers use very high quality material in their engine blocks, but the environment in which we run them and the hard impacts that are common with exposed engines can crack an engine block. I don't believe there is one engine that is more predisposed to this type of damage - you'll usually find this type of damage in proportion to the number of engines sold. So, an engine that sells more will experience a higher number of damaged blocks just because of of their numbers in the market.
I've been fortunate enough to see the manufacturing process of many engine manufacturers and, at least during the time I last visited a number of engine factories, OS was using the most advanced and precise processes available. Their quality is outstanding and their technology is the best in the business.
Nothing surprises me regarding breakage of engines and other parts that we normally assume are extremely durable, because I've also seen some of the wrecks that have caused this type of damage - when you run that fast and crash that hard, stuff breaks.
SteveP is offline   Reply With Quote
Old 12-10-2009, 03:03 AM   #25
merdith6's Avatar
Default Most advanced
usually causes all kinds of problems, look at the ammount of problems with os engines over the years. Bearings, rods, crankshafts, oh yeah my favorite, the carbs, and now the cases, what's left?
merdith6 is offline   Reply With Quote
Old 12-10-2009, 03:13 AM   #26
SteveP's Avatar
So how many OS engines have you owned that have experienced all these problems?
Old 12-10-2009, 05:34 AM   #27
Maximo's Avatar
You hear of more OS engines breaking cases then any other brand...high tech or not they dont have a strong case ! Picco cases are much beefier and stronger !
Old 12-10-2009, 05:55 AM   #28
cary's Avatar
Trader Rating: 67 (100%+)
only broke the mounting ear off a V-spec (bashing)
but have not had a problem sense. but now
I only use king headz motor mounts
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 12-10-2009, 06:46 AM   #29
Integra's Avatar
I beg to differ.
Old 12-10-2009, 07:34 AM   #30
wingracer's Avatar
I would agree but his point was that of course you will see more OS motors break because there are more of them on the track.
Numbers vary from track to track but typically if there are 50 racers at a track, 30 of them are using OS motors. So, if we assume this is a really tough track and 10% of racers will have cases break, that's 3 OS motors broken to only 2 of all the other types combined despite the fact that all the motors had the same failure rate (in this hypothetical example).
Team Shepherd USA
