Old 12-08-2009, 11:43 AM   #1
Default NOOB question........
Im just getting into 1/8 buggies, I just got a used hyper7 pbs yesterday. I have a FM radio that I use with my Adam drake2 I was wondering if I could take the crystals out of that car and put it into my hyper so I could use the fm radio with my hyper?
Thanks for the help guys!
crockpot7 is offline   Reply With Quote
Old 12-08-2009, 11:49 AM   #2
smokinu's Avatar
Trader Rating: 60 (98%+)
if they are both fm... and the mhz (there is 27 and 72mhz bands)
then it will work just make sure the radio your taking them out of is the same mhz band as the one you are putting them into.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 12-08-2009, 11:56 AM   #3
houston's Avatar
Trader Rating: 91 (100%+)
one way to find out try it
there are negative shift and positive shift for fm tx/rx also single conversion , high response and dual conversion tx/rx as well as crystals
hope this helps ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-08-2009, 12:17 PM   #4
So should I switch the entire receiver rather than just the crystals?
Old 12-08-2009, 09:21 PM   #5
tom2tone's Avatar
Trader Rating: 98 (100%+)
Switch both so that way it's the same set up. Then you don't have to worry if something goes wrong.
TEKNO EB48.3 / ET48
AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
