Old 12-06-2009, 05:31 PM   #1
Frank L's Avatar
Trader Rating: 148 (100%+)
Default DX3R issue
I have been using a DX3R for quite awhile, pretty much a few months after it came out. I experienced an issue yesterday that I did not expect. The transmitter worked fine in the morning at practice and then when quals started model #2 on the transmitter just stopped working. I thought it needed to be re binded but it would not bind, I checked the receiver with a backup and still same thing it would not bind, finally a buddy suggested that I try a different model # on the transmitter and that was it. I know I can send it back and they will take care of it, but I was wondering if anyone had a similar issue and if it got worse or if it just stayed with 1 non-working model?
Old 12-06-2009, 08:46 PM   #2
I had one do the same thing. I kept trying for 2 weeks after it happened and it never worked so I sent it in. Maybe try the Radio/Electroncics thread. Someone might know in there. Good luck
mugendriver23 is offline   Reply With Quote
Old 12-06-2009, 11:18 PM   #3
carlosm's Avatar
Trader Rating: 17 (100%+)
Frank Check this out: http://www.spektrumrc.com/Articles/A...ArticleID=1784
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 12-07-2009, 05:04 AM   #4
Originally Posted by carlosm View Post
Well I thought Frank said he tried to re bind it again but nothing happened. So im not sure that article is what he is looking for because it just tells you to rebind the radio and receiver.
Old 12-07-2009, 05:20 AM   #5
Trader Rating: 15 (100%+)
Frank I think there is an option there somewhere to do a master reset. It will reset all your epa's and such but it would be worth a shot. This is just an idea and I haven't tried it. If that doesn't work I'm not sure your gonna get the answer here and you probably should just send it in.
Jonathan Bell is offline   Reply With Quote
Old 12-07-2009, 08:21 AM   #6
Frank L's Avatar
Anks guys for the response. Ya I did try to rebind and try and try it's like that model # just died. I just don't want it to get worse. I'll try the radio/ electronics section thanks.
