Old 12-06-2009, 05:01 PM   #1
Default losi rear diff vs os.28
is there anyway to runn a .28 in a 8ight 2.0 without blowing the rear diff i striped the gear 3 times already the only thing im told is to shime it tighter?
jaredk l8 is offline   Reply With Quote
Old 12-06-2009, 05:06 PM   #2
JBURCH's Avatar
Why would you want a .28 in a buggy??? But there have been some that have and had no problems with the rear diff. what are you blowing the spider gears or the ring gear??
JBURCH is offline   Reply With Quote
Old 12-06-2009, 05:16 PM   #3
Integra's Avatar
replacing R+P's is a match set....if you blow 1 gear the other needs to be replaced as well...if your just throwing Ring gear's at the problem meanwhile the real problem is the pinion....you'll forever have problems.
Old 12-06-2009, 05:22 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
And when you replace the ring and pinion dont forget to replace the gear case too as its the reason why these r/p are blowing up.
Old 12-06-2009, 06:19 PM   #5
Unsober1's Avatar
I too had a problem with the rear diffs. What is a cheaper and easier fix is to buy a complete setup from ebay that is pulled apart from a kit
Fusion Motorsports----- www.novarossiusa.com
AB Mods ----- www.abmods.com
Unsober1 is offline   Reply With Quote
Old 12-07-2009, 08:30 AM   #6
Integra's Avatar
i was actually forced to replace the case due to wearing a hole Right through the bottom piece that keys into the chassis......Noticed dirt in with the R+P Grease and upon further inspection found a flippin hole in the case.
Old 12-07-2009, 08:59 AM   #7
its a truggy sry
Old 12-07-2009, 01:18 PM   #8
Integra's Avatar
Originally Posted by jaredk l8 View Post
its a truggy sry
what is failing ? the R+P or the Spyder gears or the cups ?
Old 12-07-2009, 02:06 PM   #9
pyromania's Avatar
Trader Rating: 18 (100%+)
+1
The whole rear diff on ebay goes cheaper than the R+P set at hobby shops.
If you're killing R+P gears, replace the R+P and gearbox and shim correctly. If you don't the problem will never go away.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 12-07-2009, 02:06 PM   #10
pyromania's Avatar
DP sorry
Jesse Carrillo
Team Driver For:
