Old 12-05-2009, 11:21 PM   #1
Trader Rating: 30 (100%+)
Default setup tips for small tight indoor track
Im racing on a really little indoor nitro track this winter and was wondering if anyone could maybe give me a few setup tips. Im running a rc8b, raced there a couple times been really fast both times, but the car needs some improving. What im needing is steering without losing traction. So what im looking for is what changes can i make to my car to give it more steering off power but still have the good on power traction. And just any tips anyone has to run on a tight indoor track. Thanks
gofast072 is offline   Reply With Quote
Old 12-06-2009, 06:00 AM   #2
Trader Rating: 61 (100%+)
see if this helps any ..just read and apply where you need it
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 12-06-2009, 06:07 AM   #3
KWT-NITRO's Avatar
hello there,
we race on a very tight/ technical track also, its small but the lap time is around 34s (very technical) i run a Kyosho MP9 and i did this to have tons of steering:
1- short wheel base (all spacers behind the rear hub carrier)
2- ackerman position all the way toward the back of the car (faster steering response)
3- .5 or 1 degree less toe in (rear)
4- .5 or 1 degree more toe out (front)
5- more camber in front
6- if you dont need alot of on throttle steering, try to use minimum caster angle.
dont do all those changes at once, you won't be able to drive the car, the driving style will change alot, try the ackerman and wheel base first with your normal set-up, if you still dont have enough steering, play with the other angles (is the spelling right?? for angles??
and keep in mind, when you gain steering, you loose a bit of rear traction, you better get used to it, IMHO its easier to drive a car that oversteers.
hope this helps
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 12-06-2009, 09:25 AM   #4
dnebout's Avatar
Trader Rating: 32 (100%+)
Originally Posted by KWT-NITRO View Post
hello there,
hope this helps
cheers
Ali
Do you have a picture or a link to a picture for your track. Relatively new and would like to know what you consider a tight track so I can compare it to ours.
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Old 12-06-2009, 09:32 AM   #5
Davidka's Avatar
Trader Rating: 75 (100%+)
Go to a stiffer spring and limit you travel a little more. You'll be driving the corners harder, lots of travel can cause excessive weight transfer. If the room the track is in is cold you may need to come down on your shock oils, they get heavier in the cold.
Run a milder engine, smaller tracks can't make use of a long legged engine.
LOSI XXX-S, Tips and Tricks, Open Mod, etc John Stranahan Electric On-Road 1044 03-08-2017 04:30 PM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-20-2015 11:54 PM
TC3 Assembly Tips, Factory Team Kit John Stranahan Electric On-Road 459 06-22-2010 01:29 PM
