Old 08-07-2011, 09:09 PM   #8551
Chad Millikan's Avatar
Send a message via Yahoo to Chad Millikan
Porkchop I think I remember you saying that the aluminum diff holder helps fix the sticky brakes. what else helps solve that besides buyingt he diff brace.
Desoto Racing l Serpent America
Serpent 811B 2.0 l Novarossi Keep-Off 21-4 l Serpent 811Be l Tekin 1900Kv l TLR XXX-SCT l Tekin 17.5
Chad Millikan is offline   Reply With Quote
Old 08-07-2011, 09:23 PM   #8552
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
the only other thing i have seen work is spray bee wax on the metal post and piston and light on fire that could help and if no just clean it
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 08-07-2011, 09:49 PM   #8553
Default Cobra Rear Shock Springs
Hello All;
With regards to the rear shock springs that work best on the 811, are the Green Losi springs the only option?. Or has Serpent come out with their own spring that is comparable to the Losi Green?. If so what "color is the appropriate rear spring to use?.
Is it an absolute necessity to get the Aluminum Center Diff Mount?. I was told that it makes the braking feel consistent on the car. Also thinking about picking up the webbed bladders and some Aluminum clutch shoes. I have all of the other goodies already; just trying to figure out what else I'm missing. Thanks.
kaneye2 is offline   Reply With Quote
Old 08-07-2011, 10:11 PM   #8554
Frank L's Avatar
Trader Rating: 148 (100%+)
The buggy seems to like stiffer springs. I went from blue to green rear serpent springs and it got a lot better. I haven't tried the yellow springs but most guys are running them. I haven't tried any losi springs. I can say that the alum center diff mount is well worth the $$. The car works very well with it and the brakes spin free.
Old 08-07-2011, 10:26 PM   #8555
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
red up front with 40wt losi oil
white in the rear with 30wt losi oil..
tappered 1.3 pistons f/r (tapper down)
8 hole pistons
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 08-07-2011, 10:40 PM   #8556
Frank L's Avatar
Are you using 6, 8 or 10 hole pistons
Old 08-07-2011, 10:51 PM   #8557
Moderator
J.Whiting's Avatar
sorry edited my first post but using 8 hole
Old 08-08-2011, 12:15 AM   #8558
heavyjeffd's Avatar
Trader Rating: 14 (100%+)
Originally Posted by kaneye2 View Post
Hello All;
Serpent springs are available from Absolutehobbyz.com
I bought the Durango spring kit from Amain because at the time, no one had Serpent rear springs. I'm not a fan of Losi springs, the spring rates are really inconsistent.
Huge thanks to my sponsors!
Team Associated | Pro-line | Avid | VP Powermaster
heavyjeffd is offline   Reply With Quote
Old 08-08-2011, 12:26 AM   #8559
Your up late
Wild Bill
serpent cobra 811TE, Cobra 811T,Serpent S411TE,rebel12 pan car, VPfuel, Buku clutches, Novi motors
1airborne is offline   Reply With Quote
Old 08-08-2011, 12:27 AM   #8560
heavyjeffd's Avatar
Haha yeah, finishing up my car for Arkansas RCPro this weekend!
Old 08-08-2011, 12:28 AM   #8561
I think I just bought a 2nd serpent buggy earlier tonight.
Wild Bill
Old 08-08-2011, 06:22 AM   #8562
Frank L's Avatar
Wild Bill
No thinking. You defiantly did
Old 08-08-2011, 08:04 AM   #8563
Ya!!
Old 08-09-2011, 11:07 AM   #8564
pballer2777's Avatar
Trader Rating: 27 (100%+)
ok i'm having alittle issue with the way the car turns. when i first took the car out my diffs were 5-5-5 i really liked how planted the car felt but the car pushed pretty bad. the rest of the set up was chads latest setup post on here, but also runnin opt 3 steering rack. so i changed the rear fluid to 3k and now the car is alittle loose in the rear more than i like. i would like to go back to 5k in the rear but don't want the push. what else can i do to help the turn better?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 08-09-2011, 11:11 AM   #8565
porkchop's Avatar
move the hubs forward some.
try a 2.5 rear bar.
try to pick up the camber link a hole to
charles garten
