Old 08-06-2011, 08:16 PM   #8536
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Try going really soft on the oils if it's a bumpy/rutted track. I was hesitant to do so, but I really like the feel of 3-3-3 so far.
Oil wise I'm using the 6 hole conical pistons running 27.5 wt all around. It's a little too stiff still, I'm going to drill the pistons out, not sure to what yet.
Huge thanks to my sponsors!
Team Associated | Pro-line | Avid | VP Powermaster
heavyjeffd is offline   Reply With Quote
Old 08-06-2011, 08:21 PM   #8537
bill marchant's Avatar
Trader Rating: 229 (100%+)
Send a message via Yahoo to bill marchant
I will try the 333 and running losi green rear and silver front springs I am running heavy shock oil 40/30 will try the half weights
Hobby Pro USA, Agama
PRS1 buggy D3 13.5/Hobbywing
Novarossi/savox
BRUCKNER HOBBIES For All your RC needs 2 FEED YOUR ADDICTION!!!
BARNSTORMERS RC/Gun Hill Racing
bill marchant is offline   Reply With Quote
Old 08-06-2011, 08:28 PM   #8538
Frank L's Avatar
Trader Rating: 148 (100%+)
I'm running the 6 hole conical drilled front 1.4/ 40wt and rear 1.2/ 27.5 wt. It feels pretty good. The conical pistons need to be drilled they come 1.1
Old 08-06-2011, 08:30 PM   #8539
heavyjeffd's Avatar
Also, when you pull your shocks make sure that your arms are getting full travel/full droop. The travel of the arms is very sensitive in relation to the ball end placement on the sway bars.
I found that out the hard way.
Old 08-06-2011, 08:33 PM   #8540
GOT IT.... Good Info guys thx for all the tips going to bring car out tomorrow and try these setup tips the more info the better
Novarossi/savox
Old 08-06-2011, 08:35 PM   #8541
Also running aluminium f/r braces car feels stiff you guys prefer the plastic for more flex
Novarossi/savox
Old 08-06-2011, 08:48 PM   #8542
heavyjeffd's Avatar
I prefer the aluminum overall.
Old 08-07-2011, 07:31 AM   #8543
Goomba_7's Avatar
I'm a half and half guy with the braces. Front plastic and rear aluminum. I haven't stepped away from the 553 in the diffs and I've been on rutted to all hell tracks and smooth tracks.
the only thing I seem to change at the track anymore is shock oil because I've been really happy with my setup as far as roll centers and etc.
And not to toot my own horn, which I don't know how i'd do that, but I always get comments about how good my car looks around the track. But never seem to get comments about my driving?!?!?! Got to work on that.
Serpent Cobra S811, Which ever engine is running good for me, VP Fuel, Savox Servos
"A bad race day is still better than a Good work day!"
Goomba_7 is offline   Reply With Quote
Old 08-07-2011, 10:39 AM   #8544
Dumb question installing the webbed bladders wich way they face??? webbed out facing piston or reversed
Novarossi/savox
Old 08-07-2011, 11:04 AM   #8545
vti-chris's Avatar
Anyone knows of any brands crown gear we could use to run 41T up front...so we overdrive it and smooth the acceleration??
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 08-07-2011, 11:16 AM   #8546
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
agama?? they use the straight cut gears.. i know some guys that are doing this on those cars... that might be an option.. check there web site...
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 08-07-2011, 11:24 AM   #8547
heavyjeffd's Avatar
The "open" webbed end goes into the shock cap. The closed/smooth side faces the piston/oil.
Old 08-07-2011, 11:29 AM   #8548
Frank L's Avatar
Ya smooth side of the bladder towards the oil.
Old 08-07-2011, 06:10 PM   #8549
jzemaxx's Avatar
I would like to know as well.
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 08-07-2011, 06:23 PM   #8550
Moderator
J.Whiting's Avatar
http://agama-rc.com/parts_search_res...p?kw=ring+gear
dont know if these will fit or not.. pinions are not an option but the ring gears might be? jeremy
