Serpent 811 Cobra Buggy
#7066
sean i told you be happy did i not
#7067
I'm having a problem unstinting this sway bar set up. The locknut that tightens down on the a-arm that holds the pivot ball it place, do I leave the nut loose so the pivot ball moves freely or do I Leave it tight so it doesn't move? The other question is I have no clue how high or low to run the pivot ball coupler that holds the swaybar, it states it in the manual but I'm not very clear on what the he'll I'm doing.
#7068
I'm having a problem unstinting this sway bar set up. The locknut that tightens down on the a-arm that holds the pivot ball it place, do I leave the nut loose so the pivot ball moves freely or do I Leave it tight so it does move? The other question is I have no clue how high or low to run thepivot ball coupler that holds the swaybar, it states it in the manual but I'm not very clear on what the he'll I'm doing.
#7069
It works really great. Just installed it. Drill a 13/64 hole through the top hole.
It fits the swivle great.
http://www.amainhobbies.com/product_...-Red-24T-Hitec
RBOR17002 Robitronic Machined Aluminum Single Sided Servo
#7071
#7072
#7075
Thats a bummer. My wife let me buy a car to be IN the wedding
#7077
I'm running Avid Revolutions and like them, especially since they offer Serpent specific bearings with the rubber seal on the flange side for the outer wheelbearings.
#7078
I'm missing a part from my kit, is there a way to get it sent to me free of charge?
It's the dark plastic that you insert the bearings into. I've looked high and low for the part and I don't have it.
#7079
Actually under further review I'm missing 4 parts total. Some parts from radio tray parts tree are missing.
#7080
Go Billy
