Old 12-02-2009, 08:04 PM   #1
dnebout's Avatar
Trader Rating: 32 (100%+)
Default Clutch Nut for Nova Plus 4 Limited
I'm trying to put the clutch nut on my new Nova Plus 4 and can't seem to get it threaded onto the crankshaft. I'm using the clutch nut from my LOSI 454 .28. Is there a pitch difference that I don't know about?
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Old 12-03-2009, 06:15 PM   #2
dnebout's Avatar
I can't believe all the feedback. It's too overwhelming. Please stop posting I figured it out..
The threads on the plus4 crank were coated with a clear hardened product. A couple of wire brush strokes and itwas good to go.
Blackjack 26
Old 12-03-2009, 09:42 PM   #3
Well good thing I didnt post yesterday. I was gonna tell you to clean out the locktite from your clutch nut because all SG shaft motors have the same clutch nut thread.
Boy would I have looked stupid
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 12-03-2009, 10:31 PM   #4
dnebout's Avatar
Yeah That's what I thought as well but after spending $300.00 and saw Italy on the box and the nut seemed to get tight when threading, I got into a frenzy over here.
Thanks.
Blackjack 26
Old 12-03-2009, 10:35 PM   #5
tc5 man's Avatar
Thanks.
did the lockout that holds the flywheel that came with the eight that dint fit
cause it go right on my nova 21 bf
Old 12-04-2009, 12:36 PM   #6
dnebout's Avatar
If by lockout you mean the (brass ferule), it was too long so i put on an extra that I had for my 8T2.0. Everything is fine now. Running othe 4th tank.
Blackjack 26
Old 12-04-2009, 01:17 PM   #7
houston's Avatar
Trader Rating: 91 (100%+)
must use the losi collet with the losi flywheel
the other collet will work for most standard 3 shoe clutches
use an adjustable wrench on the outside of the clutch where the clutch pins thread into to keep flywheel still while tightening .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-04-2009, 03:35 PM   #8
dnebout's Avatar
Yeah I've got a decent set of Tamiya Channel locks with nylon protection. Thanks for taking my call today. It was nice getting some insight from you on the Nova motor.
Tx
Dave
Blackjack 26
Old 12-04-2009, 03:40 PM   #9
houston's Avatar
Tx
Dave
no prob dave
i do what i can bro
my responses and recommendations are based on real world world everyday race applications , things i have tested , tuned and otherwise learned not to do that type of things
1/8 Tire Lot/ Nova N21BF Limited/ M8 Radio/ Go Carb/ Nova Cooling Heads "Smiley" R/C Items: For Sale/Trade 18 11-02-2009 09:29 PM
2007 Team Magic G4+ Limited Edition Sow&Steady Nitro On-Road 253 06-03-2008 02:12 PM
