Old 12-02-2009, 02:44 PM   #1
dnebout's Avatar
Trader Rating: 32 (100%+)
Default Taping Wheel Foams
Does anybody here tape wheel foams to stop the balooning effect at High RPMs? If so, do you do it to any of the higher end tires like the Proline VTRs or LPRs?
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
Old 12-02-2009, 03:02 PM   #2
tc5 man's Avatar
i have seen people do that before to there monster truck tires yea i would think though that vtr would help since there lower profiles or my guess whould be thicker oil in the front not sure
Old 12-02-2009, 04:10 PM   #3
DANE_TRAIN's Avatar
Trader Rating: 20 (100%+)
Tc5 man, I'm not the best at grammar or spelling, but your posts are very hard to understand. For as much as you post, the least you could do is proofread and use punctuation.....just a thought.
As far as taping foam inserts, I think its a bad idea. Over time the tape could work free and could cause an unbalanced wheel. If you are having problems with "ballooning'' tires, you should try LPR tires and/or AKA foam.
Pro4mance Hobbies
DANE_TRAIN is offline   Reply With Quote
Old 12-02-2009, 04:14 PM   #4
smokinu's Avatar
Trader Rating: 60 (98%+)
and you dont tape the foam...
you turn the tire inside out and put two wraps of duct tape around the inner tire... the rubber is what balloons not the foam.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 12-02-2009, 04:35 PM   #5
dnebout's Avatar
You're right it is the tire you tape. Now I remember. Anyway what do you think about taping?
Blackjack 26
Old 12-02-2009, 05:48 PM   #6
smokinu's Avatar
the new lpr and vtr truggy tires dont need it
but if you have an mt or soemthing or mtr/mt tires they do need it as they are a bigger/wider wire.
Marcus P.
Old 12-02-2009, 06:54 PM   #7
dnebout's Avatar
ok then I'll buy the LPRs and VTRs with rims that way I don't have to mess with glue. What do you do? Do you buy the rims and tires seperate? Do you put holes in the rim or the tire for drainage and breatheability? Do you try to salvage rims or just say f-it and throw the whole lot away?
Blackjack 26
Old 12-02-2009, 06:59 PM   #8
cluffy1's Avatar
i have just finished taping all of my tires. i tape the tire not the foam. makes it very easy and does the same job.
go hard or go home
cluffy1 is offline   Reply With Quote
Old 12-02-2009, 07:02 PM   #9
dnebout's Avatar
Do you do it to Proline Tires VTRs and LPRs? Do you punch holes in the tires?
Blackjack 26
Old 12-02-2009, 07:09 PM   #10
cluffy1's Avatar
i will put holes in the tires if i find i need them after running them to see. so far i haven't needed them and don't want to put holes in them as i would just get crap inside to tire. i have don't this to GRP and VP Pro tires not proline Yet but it is the same process.
go hard or go home
Old 12-02-2009, 07:25 PM   #11
dnebout's Avatar
My stock XTT tires have clumps of dirt in them btween the foam and the tire. They weigh alot now and are completely out of balance. Losi put the holes in the rim and I dunk them in water when i clean them. I guess I probably shouldn't dunk them in water.
How do you guys clean your tires?
Blackjack 26
Old 12-02-2009, 07:31 PM   #12
cluffy1's Avatar
step 1
remove tire from rim(doesn't have to be both sides)
step 2
roll the tire over the layed out tape
step 3
place foam back in
step 4
glue and run
easy
this was just a demo. you should take your time taking the tire off the rim and make sure everthing is clean.
go hard or go home
Old 12-02-2009, 07:36 PM   #13
cluffy1's Avatar
if they don't need a clean then i leave them but if i do clean them then i clean them in soppy hot water and leave to dry for about 2 weeks.
go hard or go home
Old 12-02-2009, 07:37 PM   #14
dnebout's Avatar
Cluffy,
Did you just do those pictures because man do I appreciate it. You didn't have to go through the trouble. TX
Do you boil the tires or put them in the oven to remov?
Blackjack 26
Old 12-02-2009, 07:44 PM   #15
imaxx21's Avatar
Send a message via AIM to imaxx21
if your buggy tires are ballooning you need to put some diff oil in your car....just a thought
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
FOR THE NEWBIES!!! IF YOU ARE NEW READ THIS omaharich Electric On-Road 54 01-18-2007 01:32 PM
X-Ray T2R Rob Janssen Electric On-Road 300 11-01-2006 04:41 AM
