Old 12-02-2009, 10:20 AM   #1
jonski's Avatar
Trader Rating: 233 (99%+)
Default Change spur or pinion?
I have a quick question...I am topping out on the straight too soon and I need to change my gearing. What is the best way to do this...bigger pinion or smaller spur. I am currently running a Hyper ST with a 52 spur and I believe a 13 pinion. I think it will be hard to get the 14 in there and if I put the 50t on there I will be able to slightly move the motor closer to the centerline of the truggy. What do you guys think?
jonski is offline   Reply With Quote
Old 12-02-2009, 10:27 AM   #2
underway's Avatar
Trader Rating: 48 (100%+)
What motor/ pipe? It may be a limitation of the engine that gearing cannot fix. I usually run the stock gearing in ALL buggies/truggies that I have run. Never saw the need to mess with gearing. If I was topping out halfway down the straight... I strap up the SPEED Horse...
underway is offline   Reply With Quote
Old 12-02-2009, 10:52 AM   #3
wallot's Avatar
changing spur gear is more granular. so it should help
52/13=4
50/13=3.85 so I would start with it
50/14=3.57 maybe too much. you have to try it
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 12-02-2009, 12:36 PM   #4
merdith6's Avatar
Default Good question....
If you were using a larger bell than I would say go down on the spur side, it's a smaller change anyway, but your bell is small, go to a 14tooth bell. It will work perfectly....
merdith6 is offline   Reply With Quote
Old 12-02-2009, 02:53 PM   #5
AkA "Tweeky"'s Avatar
your gearing sounds really high to me/ I run a 14/48 It does good on big and small tracks.
Losi L8ight, Novarossi, Hitec HV, Byrons Fuel
Kyosho RT5, Novak, Hitec, SMC
SC10, Novak, Hitec, SMC
AkA "Tweeky" is offline   Reply With Quote
Old 12-02-2009, 02:57 PM   #6
jonski's Avatar
I am running a NovaRossi N21BF with a 086 pipe.
64 or 48 Pitch and why wiscnitro Electric On-Road 35 08-28-2009 09:11 PM
Pinion/spurs? rsxskyd Electric On-Road 30 09-21-2007 07:33 PM
Spur and pinion Pitch doublest Electric On-Road 16 05-05-2003 03:19 AM
Flywheel, spur gear, air flow and other questions alucard13 Nitro On-Road 9 03-28-2003 04:29 AM
