Old 12-02-2009, 03:26 AM   #1
Default servo horn
hey guys i have an issue with my servo horn slipping on the servo when braking causing my truggy to fully accel after i brake. is there a metal horn avalible? im a real noob to this so any help would be great.
rb2b4 is offline   Reply With Quote
Old 12-02-2009, 03:39 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yes, there are metal horns available for most servos. What brand is the servo?
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 12-02-2009, 03:46 AM   #3
its a hitek metal gear
Old 12-02-2009, 12:32 PM   #4
aaron joy's Avatar
Trader Rating: 16 (94%+)
Are you using the correct spline count (teeth on the servo output shaft)?
Hitec is 24 spline, maybe you have a 25 spline by accident.
aaron joy is offline   Reply With Quote
Old 12-02-2009, 12:41 PM   #5
merdith6's Avatar
Default end point adjustments, try new horn....
Oh yeah, there are a lot of aluminum servo horns out there, the racers edge ones are cool. but if your stripping out the plastic ones you may really chew up the servo with an aluminum one. Check the end points, and tone down the brakes a little bit.....
merdith6 is offline   Reply With Quote
Old 12-02-2009, 03:53 PM   #6
I used one of the horns that comes w/ the hitec servo. I had to do a slight modification because it was too long. They are plastic, but super durable.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 12-02-2009, 04:18 PM   #7
smokinu's Avatar
Trader Rating: 60 (98%+)
the hitec red servo horns are pretty durable..
but robotronic has a nice clamping alum horn.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
What servo horn for Ace 1015? spawn_x Nitro Off-Road 20 07-29-2009 02:18 PM
