Old 12-01-2009, 02:05 AM   #1
Default EFRA numbers... Help
Hello all,
I am pretty new to the nitro scene. I have been looking into getting a new pipe and have seen EFRA numbers. I have looked into the EFRA it seems to be more or less a euro sanctioning body of rc...
Long story short is a pipe manufactured by two different companies with the same efra number for the most part going to be the same thing design and performance wise and the differance comes down to things like build and material quality???
ooooooorrrrr... are they two completely animals all together?
Thanks for your input!
Jonathan
Slash
AE B4 w/ murfdogg 17.5
AE SC10
AE RC8
TRX Nitro 4-tec
MangDeezy is offline   Reply With Quote
Old 12-01-2009, 02:48 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
The EFRA number is a homologation number. In other words, every exhaust carrying that number needs to be a copy of the one that is homologated.
Mostly a different brandname is just written on it by the original manufacturer (OEM)
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-01-2009, 11:47 AM   #3
so for instance i am looking at the 2013 for my new werks b5 and any company that makes a 2013 pipe will be the same thing?
Slash
AE SC10
AE RC8
TRX Nitro 4-tec
Old 12-01-2009, 12:05 PM   #4
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
If the EFRA number is the same yes, they are identical pipes.
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Old 12-01-2009, 12:10 PM   #5
Roelof's Avatar
The 2013 is published by many names as Mega, Sirio, RB etc. All were made by Starmotor as also the Werks engines and pipes.
Yes, a 2013 is a 2013 and may not be different than a 2013
Old 12-01-2009, 12:32 PM   #6
sicsam's Avatar
SO this means all 053 and 086 pipes are the same?!
Battlefield R/C
sicsam is offline   Reply With Quote
Old 12-01-2009, 12:37 PM   #7
hambone's Avatar
No way. Close. They all have slightly different manifolds also. Slight differences in materials and wall thickness make them resonate a little different. Alot of the differences are picked up on the dyno, but they are so close it's hard to tell on the track.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 12-01-2009, 12:48 PM   #8
houston's Avatar
Trader Rating: 91 (100%+)
you dont see efra numbers designated to most 53 or 86 based pipes
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-01-2009, 12:50 PM   #9
sicsam's Avatar
just dont make since why they would use the same number on another pipe if they're not the same thing
Battlefield R/C
Old 12-01-2009, 01:26 PM   #10
wingracer's Avatar
Trader Rating: 23 (100%+)
I believe 086 and 053 were the original Novarossi numbers. They were homologated by EFRA as 9886 and 9853. Since they are no longer legal in europe (at least in onroad, not sure about offroad) they don't put the EFRA numbers on them anymore. Because of this, I believe some of the cheaper 086 and 053 pipes are copies made by someone other than Nova so the differences may be greater. Not sure about this though.
Pipes with the same number but with different brand names are usually the same pipe; however, manufacturing differences can lead to different performance even within the same brand. Plus, manifolds can be quite different. For example:
I used to have two onroad 2015 pipes. One was a JP, the other was a Top I think. The pipes were IDENTICAL except for the name but the manifolds they came with were totally different. They didn't even look the same. The JP manifold on either pipe resulted in more top end, less bottom and much worse fuel mileage.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-01-2009, 02:37 PM   #11
wallot's Avatar
from technical point of view. yes, but sometimes they can differ in material quality if they are really manufactured by different companies and not just rebranded
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 12-01-2009, 03:07 PM   #12
Amoeba's Avatar
Probably a case of difference between "brand" number/name and EFRA number designation, as wingracer points out earlier.
A company can get a design EFRA homologated and a number assigned and then license that design to other manufacturers, this happens all the time in other industries with similar certification bodies.
I doubt EFRA takes into consideration materials composition/heat dissipation (which would cause a change in performance if you had an identical pipe but one in billet aluminum and the other in tin/gold/playdoh/whatever). More likely it's just physical dimensions and acoustic characteristics when they do the homologation testing. Based on the information I've managed to find in the EFRA rules and documentation it is only acoustic-related testing. If this is the case, that would explain the technical differences you're pointing out with some manufacturers using a design but choosing different materials... as well as difference in manifolds affecting performance for pipes that aren't one-piece.
With all that in mind, for most intents and purposes if you got 2 pipes with the same EFRA number, their performance is going to be pretty damned close to identical.
Have we sent the OP into a coma with all this info yet?
Erin Carroll
Old 12-01-2009, 07:07 PM   #13
madweazl's Avatar
I read the EFRA rules in its entirety and couldnt come to this conclusion. Perhaps my reading comprehension just isnt that good but about the only thing that I could surmise to be the same was the db level.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 12-01-2009, 10:02 PM   #14
wingracer's Avatar
If a pipes dimensions and design are not identical to the one originally submitted, it must be sent in for testing and assigned a new number. Sirio ran into this at the TC worlds when the pipe they were using had a different stinger design than the originally submitted pipe. It was therefore banned for the mains.
Team Shepherd USA
Old 12-01-2009, 10:04 PM   #15
wingracer's Avatar
I imagine sound levels are the only thing actually "tested" but EFRA does have strict guidelines about the design and dimensions of the pipes as well.
Team Shepherd USA
