Old 12-01-2009, 01:05 PM   #16
rider313's Avatar
Trader Rating: 94 (100%+)
Originally Posted by rccardude04 View Post
Personally, I say to race a couple times before you do anything at all to the truck. Get a feel for what you need to upgrade, if anything. If you're still bouncing off the walls, the LAST thing you need is a stronger engine, or to go changing diffs and shock setup just to have the thing be a different truck each time you drive it. Just keep a few bucks in your pocket in case you need to buy a factory team shock tower when the stock one bends, or if you break the steering servo, etc.
I'll bet the first thing you change will be tires and steering servo. Tires will almost be necessary, but if your track has good traction and you drive like everyone I've ever seen go to a track for the first time (even if you have a lot of practice otherwise), nothing will be a better upgrade than some track time.
Heck, I've been racing for several years now, on and off, and still find myself wishing I hadn't wasted time on setup and just drove the truck while working on hitting the fast lines and getting more consistent.
-Eric
+1, when i raced i had the wrong tires on in practice and was bouncing off the walls so i put the hot tire in aand it was hooked. plus the stock motor and pipe are good together. once i race tuned the motor i lost a second a lap due to to much power. I say once you can do 4+ laps with out crashing then you can start changing stuff
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
