Old 11-27-2009, 08:19 PM   #1
Potoczak's Avatar
Trader Rating: 111 (100%+)
Default What is the difference between RC8T-LE and RC8T-CE
Was under stomerhobbies web site and the championship edition is cheaper then the limited edition. Does anybody know why, i thought the CE was supposed to have all the upgrades.. Please help looking at buying one but dont know witch one....
Potoczak is offline   Reply With Quote
Old 11-27-2009, 08:29 PM   #2
tc5 man's Avatar
i think the limited edition just comes with the jconcepts rims and the j concepts tires i think it also comes with a losi eight -t 2.0 kind of looking body
you sure u want to go electric by the way .
Old 11-27-2009, 08:40 PM   #3
tc5 man's Avatar
i just look at the limited edition and the championship one on stormer i looks like it the limited ediction has the same thing as the championship one inless they dint update the specs not sure,go to www.teamassociated.com
i just seen whats the diffrence
Old 11-27-2009, 09:16 PM   #4
There is a thread about this already
Chris Reilly is offline   Reply With Quote
Old 11-28-2009, 12:36 PM   #5
Potoczak's Avatar
Can you please send me a link
Old 11-28-2009, 01:15 PM   #6
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
it comes with the jconcpets punisher body on it. it love the looks of it. bit i didnt know it came with jc wheels. sweet.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 11-28-2009, 02:28 PM   #7
After TQ'ing all four rounds of qualifying, Team Associated's RC8T Factory Team kit took first place at the 2009 ROAR Nationals! Driven by Ryan Maifield and powered by the Reedy 121VR .21 competition engine, the RC8T performed as it was designed to and brought home the big win!
Inspired by this achievement, Associated is proud to introduce the RC8T Factory Team Championship Edition Kit. The RC8T CE kit has added many new features to the original RC8T that make it an even more potent race machine. Improved strength, durability, rough track handling and overall performance are all qualities built into the RC8T CE making it the most competitive Team Associated truggy to date.
RC8T Factory Team Championship Edition Kit Features:
• Pre-assembled shocks, diffs and turnbuckles with Factory Team shock and diff fluids included.
• Factory Team 16mm "Big Bore" threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for durability and reduced stiction.
• Updated 5mm 7075 blue aluminum shock towers with additional rear camber link options.
• Revised front upper camber link assembly allows for easier adjustments and maintenance.
• 7075 blue aluminum suspension mounts key into chassis for maximum durability.
• Molded bushings allow for easy adjustment of caster, rear toe-in, rear anti-squat, and front kick-up.
• Updated steering geometry for more consistency and reduced bump-steer.
• Molded composite radio tray includes optional forward placement battery box for increased corner speed.
• Molded composite front and rear chassis braces for increased chassis response.
• Blue aluminum Narrow hex adapters with pin retainer clips and nylon locking wheel nuts.
• JConcepts Punisher body features a low profile design for a lower C.G., improved air flow and quicker fueling.
• JConcepts Illuzion wing pre-drilled for RC8T.
• JConcepts tires and foam inserts.
• Three aluminum clutch shoes with full sets of 1.0mm and 1.1mm clutch springs.
• Factory Team 7075 blue aluminum one-piece top plate.
• Lightweight 3mm 7075 hard-anodized chassis.
• 4.30:1 ratio gearboxes with a 14T clutchbell and 54T spur gear.
• Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates unwanted brake drag.
• Two-piece split-center diff mount allows easy access to the center diff.
• 3.5mm light CVA drivetrain with full ball bearings.
• Rear molded CVA boots to keep dirt and mud out of rear joints.
• Lightweight engine mounts.
RC8T Factory Team Championship Edition Kit Specifications
Scale: 1:8
Power: Nitro
Length: 555mm
Width: 410mm
Wheelbase: 375mm
Track: 346mm
Weight: 4230g*
Internal Gear Ratio: 4.30:1
Drive: 4WD
*Actual weight will vary depending on the engine, exhaust, electronics and tires used in the finished kit.
Recommended engine for this truggy:
#800 Reedy 121VR .21 Nitro Engine
$429.99 MSRP
UPC: 84695 00800
Old 11-28-2009, 02:35 PM   #8
RC8T Factory Team Limited Edition Kit
Team Associated is offering a limited quantity of the world-famous RC8T Factory Team kit with many of the Factory
Team option parts that Ryan Maifield used on his truck to capture the 2009 ROAR 1:8 Scale Truck National
Championships!
Factory Team Additional Option Parts Included in the Kit
• 89460 RC8B Aluminum Suspension A-Plate
• 89461 RC8B Aluminum Suspension B-Plate with pins
• 89462 RC8B Aluminum Suspension C-Plate
• 89463 RC8B Aluminum Suspension D-Plate with Pins
• 89471 RC8B Molded Composite Radio Tray with Battery Box
• 89378 RC8T Aluminum Chassis Brace, front
• 89379 RC8T Aluminum Chassis Brace, rear
• 89158 1.1mm Clutch Springs
• 5429 Silicone Shock Fluid, 35wt
It also has the carbon fiber shock towers, RC8 Wing and body.
Also included in the RC8T Factory Team Limited Edition Kit – The JCONCEPTS GOLDEN TICKET! The Golden Ticket allows you
to purchase a bundle package of JCONCEPTS accessories including the latest body, wing and tires, all at a savings of $50.00 below
normal price!*
RC8T FT Limited Edition shown with JConcepts Golden Ticket bundle package.
*Golden Ticket offer redeemable only through JCONCEPTS.
fluids included.
• Factory Team 16mm “Big Bore” threaded, hard-anodized shocks feature heavyduty
stiction.
options.
maintenance.
and front kick-up.
See next page for more features!
#80912
MSRP: $899.99
UPC: 84695 80912
Availability: December 2009
wheel nuts.
• Heatsink brake discs with “FFC” Free Float Caliper brake system eliminates
The best value and better package is the Championship Edition BY FAR!
jneg is offline   Reply With Quote
Old 11-28-2009, 02:49 PM   #9
tc5 man's Avatar
if it was me i would go for the factory team championship ediction i mean look at the parts u get and u get j concepts tires and rims its worth the price
Old 11-28-2009, 03:29 PM   #10
You get all the updated parts.
Old 11-28-2009, 08:33 PM   #11
Potoczak's Avatar
Thanks for all you help guys just preordered my championship edition from stormer hobbies.
Old 11-28-2009, 08:37 PM   #12
Potoczak's Avatar
I am still stuck between nitro or electric what do you guys think..
Old 11-28-2009, 08:48 PM   #13
tc5 man's Avatar
i would stick with nitro intil theres a class for them which i dont see intil 2011 or 2012 and i think it also depends on what track u go to, like hobby hut there was 1 electric truggy and 1 electric buggy so they pretty much had to run with the nitros if u ask me nitro is easy to drive cause it has some lag in the allection and it feels like u are in more control than a fast brushless buggy
what dont u like about nitro u can make them pretty quick off the line with diffrent clutch springs setups,i run a nova .21 bf 3 port thats $150 and it rocks when its tune right and it can run with the more expesive engines
and i drove a modded one on a truggy and its wicked on them
Old 11-28-2009, 09:12 PM   #14
tc5 man's Avatar
plus man nitro just more exiting the smoke and speed etc i know a lot people on here would agree and i think u will like also
Old 11-28-2009, 11:49 PM   #15
Rampokker's Avatar
Nitros are a lot of fun, but they do take a fair bit of maintenance. And tuning them can also be a bit daunting when you're new to it.
Electric on the other hand has way faster acceleration, no tuning, and less maintenance.
It all depends on what you want out of it. If you just want to "plug and play", then go for the electric option. If you're not scared of tuning and maintaining a nitro, then go for it. Either option is sweet!
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
