Old 11-26-2009, 08:48 AM   #1
jonski's Avatar
Trader Rating: 233 (99%+)
Default Motor Dies?
What would cause a motor to die after the straight away...when you let off of the throttle. It is a brand new Nova N21bf, but put the clutch on it that I got with the truck (used). The motor will restart with no problem and sit and idle also. Would this be a good clutch setup I could use?
http://cgi.ebay.com/Team-Associated-...item2ea9427c49
Looking for something with easy to find parts. My local hobby shop deals with the common companies.
jonski is offline   Reply With Quote
Old 11-26-2009, 08:56 AM   #2
aaron joy's Avatar
Trader Rating: 16 (94%+)
Sounds like your high-end needle may be to lean. High-end needle takes care of just that, your high speed on a straight away. Open up the high-end a full turn (richen) and retune, turning it back in one hour at a time until you get good power and smoke.
Associated makes a good clutch, what truck do you have?
aaron joy is offline   Reply With Quote
Old 11-26-2009, 09:08 AM   #3
323 R/C Racing's Avatar
Check your fuel lines. Make sure you don't have a hole or crack. Sounds to me like you don't have good fuel pressure.
Hot Bodies
323 R/C Speedway
Clockwork Race Engines
Answer RC USA
Werks Racing
323 R/C Racing is offline   Reply With Quote
Old 11-26-2009, 09:17 AM   #4
rccardude04's Avatar
Send a message via AIM to rccardude04
In my experience, the low speed needle is typically just a little lean when this happens. You're probably very close though. I would lean the LSN 2 hours and see what she does. You may have to raise the idle stop just slightly afterwards.
Also, Aaron has a good point to make sure your HSN is set correctly. If it's too lean, you will never get the LSN set right.
-Eric
rccardude04 is offline   Reply With Quote
Old 11-26-2009, 12:29 PM   #5
jonski's Avatar
I am running a Hyper ST pro version...actually have 2, one for me and one for my son.
