Old 11-25-2009, 02:20 AM   #1
Default Proper Gear mesh
I have a RC8T and will be installing the engine. How do you guys set this up to get the right gear mesh.?
bguad
bguad is offline   Reply With Quote
Old 11-25-2009, 02:32 AM   #2
It is a matter of feeling, I believe.
But some people use a piece of paper between the spur and the clutchbell. Then they push the motor & clutch-bell as far in as they can, and then remove the paper. But I haven't used these, so I don't know if it works.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 11-25-2009, 03:27 AM   #3
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
Fold the paper so its a sheet thicker.
But most of the time i just feel for it...Not too much play but not a whole heap either...A happy medium is what i call it!
Funking-Awesome is offline   Reply With Quote
Old 11-25-2009, 03:51 AM   #4
GRANPA 67's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to GRANPA 67
Cool
bguad
Yes paper method does work, i personally have never used it, If you are bout to install engine, bolt ur engine mount to ur motor, sit mount with mota attached over holes in chassis, put 2 screws in mount, not opposite, but diagonally, dont tighten too much, just firm so you can slide motor mount. once clutch bell is touching spur gear, hold spur gear with a finger and move
clutch bell, should only rock back and forward(approx 1-2mm), but keep in mind, that once you tighten up the screws, it may decrease the movement
between the gears, if it tightens, just loosen screws slightly and move mota a fraction, then re-tighten, if ur gear mesh is too tight, you will hear it when ya move truggy back & forward, also dont forget to use loctite on screws under chassis(bottom) And if you have to remove ur mota in future, take out the screws that hold mota to engine mount..hope this helps ya..good luck..
ASSOCIATED RC8B3 , NINJA B02 , HITEC, SANWA, AKA , DHAWK RACING
ASSOCIATED RC8T, NINJA B01A , HITEC, SANWA, AKA, PROLINE , AVID
LOSI 5IVE, ZENOAH 29cc, HITEC, SANWA, DDM, TEAM GONADS, TURTLE RACING
SHUT THE GATE ON THIS ONE , IT`S THE DUCK`S GUTS , IT SUCK`S NITRO..........
GRANPA 67 is offline   Reply With Quote
