Old 11-24-2009, 11:14 AM   #1
Trader Rating: 29 (100%+)
Default BIG PROBLEM!
i run a novarossi 21-4 and the case cracked from the SIC and i guess it finally gave and actually cracked near the engine mount holes. well, i got a new case in and i was putting everything back in there and when i put the backplate on, i was tightening it and the head broke off the screw and now i have half of a screw stuck in the block. i was thinking about just sealing it good around there and on the backplate, but it's really annoying me. is there any way i could get that screw out?
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 11-24-2009, 11:17 AM   #2
hdcruzer's Avatar
Take the back plate off. There should be enough screw that you can use small vice grips and back it out that way.
hdcruzer is offline   Reply With Quote
Old 11-24-2009, 11:22 AM   #3
mblgjr's Avatar
Trader Rating: 86 (100%+)
Left-handed drill bits work best for me.
Also, if it broke clean and you can pull the backplate off...
Try heating the block some, spray some penetrant (PB 'Blaster) or other light-oil down the hole and take a sharp pick and 'push' it counterclockwise.
EZ outs aren't a viable option.
And don't overtighten the backplate screws next time Hercules
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-24-2009, 11:23 AM   #4
Or you could remove the back plate and cut a slot in the screw and use a flat head screw driver to remove it. You want to cover the open space so you don't get any metal shavings inside the motor if using this method.
Always check you motor mount screws and you'll be fine.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 11-24-2009, 11:25 AM   #5
the only thing with that is that the screw is in from flush and i wouldnt be able to slot it with a dremal.
Old 11-24-2009, 11:27 AM   #6
lol yea. i might try a left-handed drill bit.
Old 11-24-2009, 12:42 PM   #7
The screw is in from flush with the back plate off?
Old 11-24-2009, 02:02 PM   #8
rider313's Avatar
Trader Rating: 94 (100%+)
you broke it good if it is. lol
also center punch the bolt befor drilling so it doesnt wander off into your new case.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 11-24-2009, 02:17 PM   #9
captain america's Avatar
I would advise caution when trying to remove a broken backplate screw; the screw shaft is notoriously close to the chamber, and with the slightest of bad moves, you could end up seriously compromising the backplate's seal.
Honestly, if it's just one broken screw, don't bother; I've been running a P5X with only 3 screws on the backplate for a couple of years with no problems.
captain america is offline   Reply With Quote
Old 11-24-2009, 02:18 PM   #10
mblgjr's Avatar
This.
Plus...
1/16" should get the job done
http://www.mytoolstore.com/hanson/hanson.html
Old 11-25-2009, 07:09 AM   #11
This.
Plus...
how would i go about center punching a bolt? what tool do i need to use?
Old 11-25-2009, 07:13 AM   #12
yes, when i was tightening it, i didnt even torque it at all and the screw head twisted off. its not that far in from flush but it is in a little bit to where i couldn't use a dremal to slot it.
alsoi, captain america. did you seal your engine when havin only 3 screws?
Old 11-25-2009, 07:24 AM   #13
rider313's Avatar
Originally Posted by slayyer View Post
how would i go about senter punching a bolt? what tool do i need to use?
just go to you local hardware store and tell them you need a center punch. It is basicly just a strong pin that makes a dimple where you want to drill so the drillbit doesnt wander on you. just a light tap with a hamer is all it takes.
Dan Williams
MNRC Chairman
Old 11-25-2009, 08:13 AM   #14
Oddly enough, all I did was put in a new backplate gasket and it was fine, though depending on your preferences, a bit of high-temp silicone around the outer edge should be more than enough to stave off an air leak; just be sure you don't get any silicone on the inner part of the cover.
Old 11-25-2009, 08:20 AM   #15
mblgjr's Avatar
If it's not in there tight, try taking a sharp pick and rotating it out first before tearing into it with the drill bit.
Try using an awl to walk it out.
http://www.everydayartiststudio.com/...Tool%20Awl.jpg
