Old 11-24-2009, 01:45 AM   #1
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
Default Which direction do Proline Revolvers run
I have just picked up a set of VTR Revolvers and have noticed that the center rows are a 'T' pin
Which direction do you guys run them in.
Im guessing they run ' -- ' forward so that the leg supports the pins
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 11-24-2009, 01:53 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
they aren't directional...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 11-24-2009, 01:56 AM   #3
aaron joy's Avatar
Trader Rating: 16 (94%+)
I don't know if there is any certain way to run them, but I personally have run them with the bottom of the "T" facing the front of my truggy. If you rub your finger across the center of the tire it feels like you get more friction with the "T" pointing forward.
Tix you running wider hubs? If not the VTR rim's inner webbing rub pretty bad on the back of the front arm. I dremel the webbing some so they don't hit.
aaron joy is offline   Reply With Quote
Old 11-24-2009, 02:35 AM   #4
TIX
TIX's Avatar
i disagree. if they weren't directional the T's would reverse each other
with the leg of the T on the back it works like a brace and puses the top of the T forward stoping the pins from rolling over. with it upside down it will have a different ammoun of support. this will give you different levels of grip depending on which way they are running
so with them all facing in the same direction it makes them a directional tire
Alan Nankervis.
Old 11-24-2009, 02:39 AM   #5
imaxx21's Avatar
if they were they would have an arrow on the side...like the Calibers
-Crash
Old 11-24-2009, 04:37 AM   #6
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
The Calibers were designed to have different traction characteristics depending on the direction. From the Pro-Line press release info:
Caliber VTR Features:
* Dual-stage pin design for exceptional tread life
* Small top pin for light to heavy loose dirt
* Base pin extraordinary on hard-packed/blue-groove surfaces
* Square-lug technology throughout the tread design
* Directional tread for two different handling characteristics
* Available in World Championship/extremely proprietary XTR (Firm), M2 (Medium), and M3 (Soft) compounds
The Revolver VTRs, which were released at the same time, don't have this blurb in the release info or a directional arrow. While the direction you mount the Revolvers will have some impact on traction & handling, it's either not intended or is an "undocumented feature". In general, most tires (rc or auto) have the lettering rotating counter-clockwise so it's readable like a scrolling marquee.
It's really up to you since I can't seem to find any information one way or the other. If running the tires "backwards" changes the handling significantly enough just remember that any traction/tire chart (like AKA has) for what situations they work best for may no longer be accurate.
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Old 11-24-2009, 05:56 AM   #7
merdith6's Avatar
Default Sure they are...
They run in a circular direction, hehe....
merdith6 is offline   Reply With Quote
Old 11-24-2009, 09:16 AM   #8
aaron joy's Avatar
He doesn't mean a "T" on the side of the tire, if you look at the center tread you will see a two stage set of pins that have a "T" for the base. They don't say anything about being directional but you would naturally think they are since there is two different tread patterns depending how you run them.
Old 11-24-2009, 03:57 PM   #9
TIX
TIX's Avatar
I'll just run them all in the same direction.
I'm not using the extended hubs. I have been running AE rims and I'm yet to have one crack. Are the VTX rims cracking or is it just the rubbing that is an issue
Alan Nankervis.
Old 11-24-2009, 04:36 PM   #10
mblgjr's Avatar
Trader Rating: 86 (100%+)
I run mine with the top bar of the "T" facing forward.
So the "T" is going headfirst into the direction of rotation.
___I___ < if that's the "T"; then the tire is rotating down the screen.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-24-2009, 09:05 PM   #11
TIX
TIX's Avatar
Thats the direction that i am planing to run them
Alan Nankervis.
Old 11-24-2009, 09:16 PM   #12
CanyonCarverR1's Avatar
It sure would be nice if Proline not only told us that Calibers have "Directional tread", but also told us what those "handling characteristics" were. Makes me wonder if it's just a sales pitch.
CanyonCarverR1 is offline   Reply With Quote
Old 11-24-2009, 09:37 PM   #13
jaylude22's Avatar
Trader Rating: 93 (99%+)
If I'm not mistaken, there's a small arrow on the sidewall of each tire that indicates direction. It can be seen to the left of the word Caliber on the sidewall when you click on the larger image on this page: http://www.prolineracing.com/product...es-255-68.html
jaylude22 is offline   Reply With Quote
Old 11-24-2009, 09:49 PM   #14
Yup but there talking about Revolvers
gizzo101 is offline   Reply With Quote
Old 11-24-2009, 10:01 PM   #15
Bigedmond's Avatar
Trader Rating: 18 (100%+)
what ever part of the block that has the sharpest block should go forward.
Bigedmond is offline   Reply With Quote
