Old 09-29-2010, 06:50 AM   #91
Integra's Avatar
Originally Posted by rcindia View Post
I thought 4S may be over kill and ordered 3S. Wont a full charged 4S be 16.8V and hurt the motors? Will the 3S work, guys?
Incorrect, standard electrical motor's we use in our boxes are rated for 18V, so therefor a 16.8v 4S will do nothing to the motor's, 18V motor's on the other hand might try and suck a little too much juice from your 3S and hurt the cell's....who told you 3S was proper ?
Old 09-29-2010, 06:55 AM   #92
stallen50's Avatar
Trader Rating: 30 (100%+)
I run 2-2s lipos. They blue lipos i got from hobbyking really cheap but work great. I got the for under 40 bucks. I have had then for about a year now still going great and no puffing
stallen50 is offline   Reply With Quote
Old 09-29-2010, 08:42 AM   #93
bad ass's Avatar
Trader Rating: 7 (89%+)
Venom Power 4S Li-Poly 20C Starter Box Battery Pack (2100mAh/14.8V)
36.99 Amainhobbies great lipo!!
Serpent/Novarossi/Maxy's Fuel/Pro-Circuit tires/Ko-Propo EX-1
DESOTO RACING
bad ass is offline   Reply With Quote
Old 09-29-2010, 09:50 AM   #94
Madbrad's Avatar
Trader Rating: 29 (100%+)
I run 3300 MAH 4S 25c lipos in both my boxes. Both from ebay, had one for over a year now and no problems so far.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 09-29-2010, 10:16 AM   #95
I just went by the voltage rating, Thought 16V will be too high. I will keep my 2 3S batteries for the Car and use the 4S on it.
rcindia is offline   Reply With Quote
Old 09-30-2010, 12:59 PM   #96
Also, is it a must to change the connectors to Deans from the tamiya ones? I see a lot of starter box batteries wired with Tamiya connectors.
Also suggest best method to secure the battery in the box. Will zip ties work? charging is an issue with ties.
Old 09-30-2010, 01:43 PM   #97
Integra's Avatar
IMO its critical to junk the Tamiya connector's, they are No where near rated for the Amps a starter box can and Will pull....deans from the pack and Direct solder everything else.
As far as securing the pack, Industrial velcro does the trick. No need for pack crushing zip ties.
Old 09-30-2010, 01:52 PM   #98
And what about charging? Do you take it out of the box and put it in the LiPo protecting bag or leave it in the box?
Donat is offline   Reply With Quote
Old 09-30-2010, 01:56 PM   #99
Suspended
Trader Rating: 202 (96%+)
i leave mine right in the box.
inferno13 is offline   Reply With Quote
Old 09-30-2010, 02:08 PM   #100
I take it out and charge it in a liposack which is sitting inside an old ammo can, but I still use Tamiya connectors. Why? Because I've never seen one burn up ever and honestly some people would burn anything up. As for securing the battery to the box I got some velcro from home depot. I stick the battery right to the bottom of the box.
They wouldn't make it if it would just melt down, they'd have 5 bazillion returns.
There is no overkill though, so if you want to you can solder some deans ultra connectors on there and if you feel better that's fine. Some lipos comes that way. Or you can use Hudy's lipo starter box connection. It just pushes onto the bare wire if you purchase a lipo that is not wired with a connector. I've also heard that the Traxxas connector is quite good, perhaps as good as deans.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 09-30-2010, 02:48 PM   #101
guss2009's Avatar
Trader Rating: 265 (100%+)
Can someone tell me what and where can i get a good but cheap in price lipo battery for my Ofna truggy starter box? I have the Blue box and i mess up 2 lipo batteries. They both got fat and one of them poped. Lucky i was outside and i have a lipo bag. The one lipo battery that got fat... It was fully charged but when i used it in my starter box, got hot and fat. I think my box was to strong for it.
http://www.amainhobbies.com/product_...er-Starter-Box
Lipo that poped
http://www.hobbypartz.com/83p-2200mah-4s1p-148-20c.html
Losi 8ight 3.0 / Losi 8ight 2.0T / CRE Werks B6 Pro / CRE P5XL / Nova 4BTT
/ Dx4r Pro / Hitec 7955tg / Nova/Werks Pipes/ Werks Pro Clutch / Werks Fuel
/ GunHill Road Track (Ft Knox Park) / NYPD
guss2009 is offline   Reply With Quote
Old 09-30-2010, 03:27 PM   #102
Integra's Avatar
Lipo that poped
what kind of charger are you using ?
Old 09-30-2010, 06:10 PM   #103
guss2009's Avatar
Im using the triton Eq charger.
Old 10-01-2010, 07:10 AM   #104
Integra's Avatar
I can assume you are balancing the packs as well ?
How many cycle's did you get before they got hot and puffed ?
Were you trying to start a tight stubborn motor ?
are you sure that the starter box has been checked out as working normal ?
Old 10-01-2010, 11:14 AM   #105
guss2009's Avatar
[QUOTE=Integra;8010623]I can assume you are balancing the packs as well ? Yes
How many cycle's did you get before they got hot and puffed ? It was a brand new battery adn only did it once.
Were you trying to start a tight stubborn motor ? No... I can turn on the engine with a 12v battery. I just wanna use lipo since is lighter to carry the box.
are you sure that the starter box has been checked out as working normal ? The box is new and work fine.
