UNDERSTANDING SERVO'S DIGITAL VS ANALOGUE
Info found on a very informative Rc helicopter site please enjoy http://www.rchelicopterfun.com/rc-servos.html
To learn more about servo operation - check this page out" .the changes have been made so it doesnt effect The writters search engine ranking with the permission of the writter. RC servos convert electrical commands from the receiver back into movement. A servo simply plugs into a specific receiver channel and is used to move that specific part of the RC model. This movement is proportional meaning that the servo will only move as much as the transmitter stick on your radio is moved. Servo Basics All RC servos have a three wire connector. One wire supplies positive DC voltage – usually 4.8 volts. The second wire is for voltage ground, and the third wire is the signal wire. The receiver “talks” to the servo through this wire by means of a simple on/off pulsed signal. Sizes Servos basically come in 3 different sizes (micro, standard, and giant or 1/4 scale) to accommodate the type of RC models they are being used in. There may be slight variations depending on the specific application but for ease of explanation, these 3 sizes cover more than 95% of all the servos out there. Speed and Torque Ratings Other than physical size, the next item that all RC servo specifications indicate is speed and torque. Speed is a measurement of the time it takes the servo to rotate a certain number of degrees. This has been standardized in most specifications to 60 degrees; In other words, the time it takes the servo wheel to turn 60°. The smaller the number, the faster the servo is. For example a 0.12 sec/60° servo rating means it will take 0.12 seconds to rotate the servo arm or wheel 60°. This would be twice as fast as a standard speed servo that is rated in the 0.24 sec/60° range. A RC helicopter tail rotor specific servo will have speeds as fast as 0.06 sec/60°. Torque determines the maximum amount of rotational force the servo can apply. This specification is measured in ounces per inch (oz-in) or in kilograms per centimeter (kg-cm). The larger the number, the more force the servo can exert. A typical standard servo will have a torque rating around 40 oz-in. A high torque specific servo can have torque values well over 200 oz-in. So what exactly does 40 ounces per inch mean? Well if you had a servo arm that was one inch long on your servo it would be able to produce 40 ounces of pull or push force at the end of the servo arm before stalling. If you had a 1/2 inch servo arm what do you think the force would be? Yup, 80 ounces of force. How about a 2 inch arm, 20 ounces of force - easy huh? I should also point out that both speed and torque specifications are usually given for the two common voltages used for receiver battery packs. 4.8 volts for a 4 cell battery pack and 6.0 volts for a 5 cell battery pack. Obviously the 6.0 volt packs give slightly higher speed and torque ratings. For RC helicopter use, only 4.8 volt receiver battery packs are generally used because of the gyros. Unlike servos, gyros are not designed to operate at voltages higher than 4.8 volts, and a 6 volt pack will damage most rc heli gyros and electronic flybarless gyro systems. -------------------------------------------------------------------------------- Digital Servos vs. Analog Servos Now onto the real meat and potatoes of this RC servo discussion. Up to just a few years ago, the only RC servos available were analog, but now we have digital. To answer the question of which is better for RC helicopters or planes and cars for that matter – let’s look at how each work and the choice will be pretty obvious. First off, there is no physical or main component difference between a digital servo or analog servo. The servo case, motor, gears, and even the feed back potentiometer all have the same functions and operations in both types. The difference between the two is in how the signal from the receiver is processed and how this information is used to send power to the servo motor. Analog Servo Operation An analog RC servo controls the speed of the motor by applying on and off voltage signals or pulses to the motor. This voltage is constant (the voltage of the receiver battery pack to be exact - 4.8 or 6.0 volts). This on off frequency is standardized to 50 cycles a second. The longer each on pulse is, the faster the motor turns and the more torque it produces. This is the same way the speeds of most motors are controlled. For instance, if you have a ceiling or exhaust fan in your house that is controlled with a variable rotary dial speed switch; the fan motor is not given lower and higher voltages to adjust the speed. The speed switch simply cycles the 120 volts to the fan motor on and off many times a second. The longer each on pulse is, the faster the fan runs. This is also the same way electronic speed controllers for electric RC helicopters , planes, cars, and boats work. Now back to our analog RC servo. At rest, there is no voltage going to the motor. If a small transmitter command is given or some external pressure is applied to the servo horn forcing it off neutral, a short duration voltage pulse will be sent to the motor. The larger the stick movement or potentiometer movement, the longer this "on" pulse will be in order to move the servo quickly to the desired position. Remember me saying that these voltage pulses are sent 50 times a second. This means that in one second, there are 50 windows that last 20 milliseconds each (50x20 = 1000 ms = 1 second). The longer each on voltage pulse is in each of these fifty 20 millisecond windows, the faster the servo motor turns and the more torque it produces. I just included this info for those of you who really want to know what makes a servo tick. You don’t have to understand all that however, as long as you understand that during small amounts of stick movement or when external forces are applied forcing the servo off its neutral or holding position; only a short duration voltage pulse will be sent to the servo motor every 20 milliseconds. With large stick movements, a long voltage pulse will be sent every 20 milliseconds to the servo motor. As you can imagine, a short power pulse every 20 milliseconds doesn’t get the motor turning that quickly or allow it enough time to produce much torque. This is the problem with all analog servos; they don’t react fast or produce much torque when given small movement commands or when external forces are trying to push them off their holding position. This area of slow sluggish response and torque is called deadband. Much of RC control, especially with RC helicopters is done with small quick stick movements moving the servo back and forth in very small increments. There are also many changing loads on the rotor system (both main and tail) that are always trying to force the servo off its hold position as well. Don’t forget about the gyro either. The new heading hold gyros or electronic flybar systems are sending hundreds of small correction changes to the RC servos every second. If I did a good job at explaining all this, you should realize by now that much of RC helicopter control and movement actually happens within the deadband area of an analog servo. This is not really that big of deal for slow human response times, but as I mentioned, a problem for lightning fast gyros and electronic flybars or advanced 3D pilots with cat like reflexes. Digital RC Servo Operation Digital servos to the rescue! Like I said before, a digital servo has all the same parts as an analog servo, even the three wire plug that plugs into the receiver is the same. The difference is in how the pulsed signals are sent to the servo motor. A small microprocessor inside the servo analyzes the receiver signals and processes these into very high frequency voltage pulses to the servo motor. Instead of 50 pulses per second, the motor will now receive upwards of 300 pulses per second. The pulses will be shorter in length of course, but with so many voltage pulses occurring, the motor will speed up much quicker and provide constant torque. Incidentally, if you have ever wondered why digital servos "sing" when very light force loads are placed on them, what you are hearing is the short high frequency voltage pulses acting on the motor. The result is a servo that has a much smaller deadband, faster response, quicker and smoother acceleration, and better holding power. You can test this very easily by plugging in a digital servo and an analog servo to your receiver. Try to turn the servo wheel off centre on the analog RC servo. Notice how you will be able to move it slightly before the servo starts to respond and resist the force - it feels a bit spongy. Now do the same thing with the digital RC servo. It feels like the servo wheel and shaft are glued to the case – it responds that fast and holds that well. Now nothing is perfect and this increase in speed, torque, and holding power does come with a small disadvantage. Power Consumption! Yup, digital servos are power hungry. All those hundreds of power pulses per second use up more battery power than an analog servo would. This really is not that much of a problem these days since battery packs have at least double or triple the capacity of what the same size/weight pack had just a few years ago. So yes, digital RC servos are much better than analog. You can still fly a RC helicopter with analog servos, but once you switch over to digital, you will likely never go back. Don’t forget about that heading hold gyro – he needs to be paired with a fast digital servo to work correctly – no exceptions! One last point I should clarify with this whole analog/digital RC servo discussion. Remember those speed and torque specifications I talked about earlier... You will find analog servos that have better speed and torque ratings than some digital servos; so why not get one of them over a more expensive slower digital? Remember, the analog servo is slow to respond and provides little torque during small, fast command inputs. Those good looking specifications are given at full stick movement when the servo has ramped up to full speed and torque. The slower spec digital servo in this case will still provide much more speed and torque where it is needed most. -------------------------------------------------------------------------------- Coreless & Brushless Servo Motors Most low cost and standard servos (analog or digital) use what is called a 3 pole electric motor. This is just a standard 3-pole wire wound DC motor – the most common type of DC motor in existence. One step up from the 3 pole is the 5 pole servo motor. As you can imagine, two more wire windings will give a 5 pole motor quicker acceleration and more torque on start up. You know by now the faster the servo ramps up to speed and the more torque it produces; the better it is for most applications. Well, improving the electric motor itself will produce more speed and torque too; coupled with digital technology, the resultant speed and torque are indeed impressive. Coreless Servo Motors: A standard 3-pole wire wound servo motor uses a steel core with wires wound around the core, this core is then surrounded by permanent magnets. As you can imagine, the core and all that wire weighs a fair bit. When voltage is applied to turn the motor, it has to first overcome this weight to get things turning – it is slow to accelerate. Once up to speed, it also continues to turn for a while when the voltage is removed – it is slow to decelerate. In a Coreless design, the heavy steel core is eliminated by using a wire mesh that spins around the outside of the magnets. This design is much lighter resulting in quicker acceleration and deceleration. The result is smoother operation, more available torque, and faster response time. Brushless Servo Motors The latest advancement is to use a small brushless DC motor in the servo. This is the exact same principle and has the same advantages as larger brushless DC motors that are used in electric RC helis, planes, and cars. There are no brushes that add drag or can wear out. Brushless motors are more efficient, provide more power, speed, and acceleration - once again raising the bar on the level of speed, torque, response time, and smooth operation. -------------------------------------------------------------------------------- RC Servo Bearings, Metal Gears, & Water Resistance These last few points are pretty basic. Bearings: You will notice when servo shopping, many specifications list if the servo has bearings and the number of bearings – usually 1 or 2. These bearings are used on the main servo output shaft instead of a simple bushing. The advantages of having ball bearings on the output shaft in a servo are pretty much the same as I talked about in the Bearing Section of best RC helicopter features – less friction and slop. Because of the many vibrations and mechanical loads placed on the servo in RC helicopters, non bearing servos do develop slop very quickly and of course this makes control more sluggish and vague feeling. Most quality RC servos, even lower cost ones these days will come with at least one bearing – this will be located on the servo output shaft where it exits the servo, this is where most of the side loads will occur. Better more expensive servos will use two bearings to further improve overall slop free performance. Metal Gears & Metal Output Shafts: Having metal gears or output shafts on servos in a RC helicopter is generally overkill and will add unnecessary weight and cost. Metal gears are used on servos that will see very high resistance and torque loads that could strip or crack the more commonly used plastic gears and output shaft. This is something we generally don’t have to worry about with helis until we start getting into very large ones that will produce significant loads on the servo. On the other end of the size spectrum is small electric helis that use micro servos. Because the servo gears are so tiny, they are not hard to break or strip in the event of a crash. A perfect example of a servo that would see constant high stress loads would be the steering servo of a RC off road car or buggy. I have a nitro T-Maxx RC monster truck that use to eat steering servos. I bit the bullet and spent a good chunk of change on a hi-torque digital servo with metal gears, metal output shaft, and metal servo arm. That was several years ago and this servo is still running strong to this day. Water Resistant/Dust Proof RC Servos Some servos are sealed to prevent water and dust from seeping inside. The case halves have gaskets, there is an o-ring around the output shaft, and there is silicone sealant where the wires exit the servo case. Now this is obviously a good servo feature for RC boating or for your monster truck when you drive it through the old mud hole. It is however unlikely you will be flying your heli under the water, in the mud, or in a dust storm. If you are, you have bigger problems to deal with than contaminated servos. That said - water resistant/dust proof RC servos do make sense with nitro RC helicopters or any nitro model that exposes the servo to nitro goo . If your RC servos are coated in nitro goo, it will eventually seep inside the servo. This won’t be a problem for the gears, but will play havoc with the circuit board and electric motor over time. -------------------------------------------------------------------------------- |
Great post, very informative, may I copy it to our Team web-site?
Originally Posted by Jaz240
(Post 6630321)
I word this as best as i can .To buy a digital servo at 6kg you might aswell buy a 13kg analogue with coreless motor at half the price as the specifications would not be much of a difference .its when you go into the larger torque servo's were digital will benefit you in speed and torque . remember speed and torque are all related to motor,gearing and voltage . Our cobra digital servo's use a 24 bit microprocessor with 4 stage programming. ok enough from me i will let you guys enjoy the info. |
very well said.
ah-ha!
i knew the difference, but i didnt know why. great read. thanks! |
You just answered pretty much every question I've ever had about servos, thanks so much.
The first time I drove my T4 after installing a new Hitec HS625, I thought I'd bought a blown servo until one of the other guys in my club explained the digital thing to me:ha: |
Originally Posted by ICBeloitRacer
(Post 6638934)
I am glad you guys are enjoying the information its info that manufacture's never explain to you indepth.
The Guy who wrote the info is John salt a very informative rc guru who is very passionate about r/c as he told me there are changes everyday in r/c he likes to keep the info up to date. I got his permission to post and would like to thank him for allowing us to use the material . please enjoy and happy thanksgiving to All my American freinds which includes all of you . |
what about the rest of it?
While this post is very informative, the information provided can be easily figured out by reading descriptions at the manufacturer's web sites and making a couple of assumptions. Nice to see the different motors described though.
What I think would be really helpful is answering all of the questions that arise mixing technologies. I think I know what's going on but I've never seen it explained in detail. Like if you still have AM or FM instead of a digital TX/RX what things you should know before deciding if that new steering servo you have your eye on should be purchased digital or if you should be considering some of the better analog ones that would perform the same - that is besides the off center torque immediately available. What the tradeoffs are for a digital servo on an analog channel and what to expect will change from the servo specifications. Also if there is anything that should never be mixed or would be a total waste of money becuase it would not be any better in an analog system but use the battery faster. Things like that. I guess for that matter someone may also wonder what would happen when you choose one analog servo for use in a otherwise digital system. I don't know why you would do that but maybe there is a reason. Like maybe you have trouble with burning up throttle servos and you want to try an analog one? I don't know. I see that one come up here alot so maybe someone might want to try that. Just trying to continue a good discussion with some stupid questions. If you are bothering to compare digital and analog you probably should know the answers to the rest of these questions too.;) |
Originally Posted by bjr48
(Post 6639647)
Just some little info after some tests and more to come .
we tested the digital servo's with the analogue Am system's and came across alot of glitching that was with 27mhz and 29mhz.so we dont recommend digital servo's on anologue AM systems we also tested with Fm systems 29mhz,40mhz and 75mhz with the digitals servo's and found no problem with glitching but the servo's did lack a little performance. Then we tried analogue servo's on a 2.4ghz digital system and had no issues a little less performance but to be honest you need to be the super eye to pick it up . The digital servo's on the 2.4ghz system were fast and alot of torque but in saying that if you were to buy a 6kg digital for so dollars but you could buy a 13kg analogue you wouldnt be able to pick the difference so why spend the money when you dont have to . Now i tried something like they try on the American show mythbusters were some say that you cannot use a digital servo and an analogue servo on a digital system . so we tried connecting a analogue servo to channel 2 and digital to channel 1 we had no problems at all with response and no interference .But when we tried to connect a digital and anaolgue servo with a y connector through the same channel yes then we had major problems with interference and glitching mama mia what a headache .so we found that on a digital system the tx processors data seperatetly to each channel so the two types on the y connector were confusing the feedback sigal back to the tx from the rx causing us the headache .but when we split the analogue and digital servo to the different channels things went back to normal . so i decided to plug in two analogues and two digitals through the Y connector just to make sure i wasn't doing anything wrong and no i was right two digital on the same channel worked well like the analogues on the other channel worked well as well .so i was happy . The radio's we used was a M11 sanwa ,dx3s and the analogues were the futaba MJ,futaba 3-pm fm. servos used ace,sanwa,mks,cobra,futaba Ill keep you posted on more tests . please if anyone else has done some testing please post so we can all read and learn . |
Wow! Thanks :nod:
I've seen a lot of advice to go ahead and use digital servos in AM systems but now I wonder how well that would actually turn out. I think I'll stick to all analog and wait and spend my hard earned money on all new setup. Leave the old buggy old and working pretty competitively with the kit and radio going on 8 years old or so and save all the extra money to spend on a brand new setup if I'm able to race next year. :nod: Very interesting info :tire: |
Very nice article Angelo !!
cya ! |
Originally Posted by Tabushi
(Post 6697970)
cya ! As for the other info it has been through our testing . |
Do you have one or just going from what you seen or heard from the worlds, they are meant to be released by the end of the year
