Old 11-22-2009, 01:20 PM   #1
Default RC8 Clutch - factory or aftermarket?
Need to rebuild my clutch and wanted to know how many of you guys use the factory clutch (and if so what type of shoe do you use) or an aftermarket clutch. Thanks.
sebkiely is offline   Reply With Quote
Old 11-22-2009, 01:48 PM   #2
Kalgard Racing's Avatar
I run the stock AE clutch with Dynamite Shoes. They last a long time and I have not had any problems.
One thing to keep in mind, the flywheel on the RC8 is different than most other flywheel due to the set back to clear the rear brake disc.
Kalgard Racing is offline   Reply With Quote
Old 11-22-2009, 03:07 PM   #3
HaulinBass's Avatar
most flywheels built for the 777 will fit, but if your sticking with the three shoe just stay stock.
For some tracks I like the fioroni twin turbo slider because its so smooth with small amounts of throttle, if your track has allot of long low throttle corners as opposed to a bunch of 90s and 180s it may be worth a try
HaulinBass is offline   Reply With Quote
Old 11-22-2009, 08:08 PM   #4
mark676's Avatar
Just ordered Impulse-rc shoes.........gotta wait till spring b4 I can try 'em though.
Mugen MBX6TR/Werks B5/m2c/2058/Savox/Spektrum
Associated T4.1
Thunder Tiger ST-1 (Shelf Queen)
mark676 is offline   Reply With Quote
Old 11-22-2009, 08:35 PM   #5
Several options.
I've used Dynamite Max-Life's, the AE 'Hard' shoes, Impulse RC, King Headz and M2C Racing.
All of them were good, but I settled on the Dynamite Max-Life shoes, as they gave me the best 'feel' for my driving style and they seem to last forever, requiring very little maintenance.
I ran the same setup in my RC8 and RC8T (maxlife/1.0 springs) in front of mild to wild motors, indoor/outdoor numerous different track conditions and they never let me down.
My $.02
McFly505 is offline   Reply With Quote
Old 11-24-2009, 02:42 PM   #6
plus2ss's Avatar
+1 on the max life shoes and 1.0 springs. Ive been running the same set for months with only minimal scuffing/sanding matinence during clutch bearing changes. Stick with the RC8 clutch, not much to go wrong and easy to find parts.
plus2ss is offline   Reply With Quote
Old 11-24-2009, 05:09 PM   #7
j_blaze14's Avatar
Trader Rating: 34 (100%+)
... and changing shoes/springs is cake, easiest out there.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 11-24-2009, 07:12 PM   #8
mark676's Avatar
So basically........stick to the ae Clutch bell and as far as shoes and springs go you can experiment ??? Also the spring numbers indicate tension measurement, right ??? And are there any differences in various mfg's springs ??
Associated T4.1
Old 11-24-2009, 07:33 PM   #9
The shoes are all made for the AE flywheel. Use AE clutch springs. You might want a set of .9 and 1.0 springs.
Chris Reilly is offline   Reply With Quote
