sketchy handling, suspension? >
Old 12-01-2009, 05:29 AM
linnix13's Avatar
Default sketchy handling, suspension?
my traxxas stampede has some sketchy handling on the tarmac, it handles great on the grass and dirt!(although it can catch a lip here and there) but on the tarmac when i gun it, the back starts skipping back and forth, until it escalates and it will then just start violently rolling, i checked and everything is tight, there are no broken or worn parts on the back, maybe the rear shocks are to stiff? what would cause this dog tracking motion?
linnix13 is offline
Old 12-01-2009, 05:41 AM
revo61's Avatar
Trader Rating: 18 (95%+)
Its a very top heavy truck, it just not designed for tarmac. You can try heavier shock oil to make the suspension stiffer. That should take some of the roll out, but to heavy and it will traction flip.
revo61 is offline
Old 12-01-2009, 06:14 AM
linnix13's Avatar
i figured it was not for tarmac, so stiff would lessen that effect?
linnix13 is offline
Old 12-01-2009, 09:53 AM
revo61's Avatar
Try stiffer first, then go softer. Problem with soft is it will most likely roll more.
revo61 is offline
Old 12-01-2009, 12:05 PM
linnix13's Avatar
oh ok, my thought was that it was so stiff that the tires would bounce and not soak up any bumps, then they slip, and it flips, when i got the car it had like 5 of
those things on the rear shocks to make it stiffer, so i took a few of, i will try it when i get home, and stiffen it if its needed, but i think your right, its not made for tarmac, its way more fun of road anyways
linnix13 is offline
Old 12-01-2009, 12:35 PM
sicsam's Avatar
Stiffer springs help alot to.
sicsam is offline
Old 12-01-2009, 02:09 PM
linnix13's Avatar
well i went out and drove it, it worked! softer shocks and its good! no more crazy crashy flips, i did however manage to have the engine bolts break, then the engine went awry and tore up the large drive gear, darn, good thing i always keep a spare in my back pocket(no really i actually do!)
linnix13 is offline
