Big Bores
Big Bores
Hey everyone, I want to put some big bores on my RC8, but i am afraid the rear end clearance is not there. The reason being: the new RC8B comes with an updated wing mount. On their website it says "... and a new wing mount for 16 mm shock clearance."
The new wing mount is almost the same, just has some material removed for clearance. A dremel can take care of it in seconds, which saves you on the wing mount.
The wing mount is just a running change, like the front arms. They wont change the part number. Its just a matter of getting through the old stock of parts.
I run the original RC8 with BB's with no problem. Slight wing mount change as has already been said. It's not that big of a deal. Don't you think you are being a little hard on AE. Have you contacted them and asked about it ?
if you have an RC8B, you have the updated wing mount. Now, if you have the Steel B plate from the old version, you really should buy all 4 of the new hinge pin plates, as they are a ton better.
[QUOTE=RC8daBOMB;6626892]yah dumb associated doesnt sell the wing mount yet... hah they are so dumb some times... I just did a little steering mod on my rc8, it steers like 2x better! muhuhahah. what springs come stock on the rc8b?[/QUOTE
AE can`t be that bad, if you have RC8 as part of ur username, and you say you have an RC8B, well the stock springs are the ones you have on it,
(Front)Bronze,(Rear)Black......
whats the stearing mod...im a newb and i just switched from 1/10 scale trucks to the rc8
