Old 11-20-2009, 08:52 AM   #1
Default Diff viscosity and heat
How much would the diff oil viscosity change from the summer months to the winter months? Do you need to use a thicker oil in the summer to get the same results?
redbones is offline   Reply With Quote
Old 11-20-2009, 08:57 AM   #2
fatdaddy's Avatar
silicone fluids do get thicker in cold, and thinner in hot, but i would think the diffs get hot enough on thier own to where it really wouldnt matter
the shocks on the other had are definately affected by the temperature
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 11-20-2009, 03:36 PM   #3
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
During the summer months here in Florida I usually run 4-6k in the front and 5-7k in the center and 2-4k in the rear. Usually with an end result being 5-7-3. Now during the winter we usually night race and its gets fairly cold in North Florida. Low 30's maybe high 20's and I will usually go 3-4-2 to smooth out the car as well as dropping the shock weight atleast 5wt. Hope this helps.
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 11-20-2009, 11:13 PM   #4
The oil in the diffs is normally thick enough that normal air temps do not effect it, any heat is built up during normal use & diff action during your runs.
So any changes would normally be done to suit track conditions only.
Bren
Bren Ralls is offline   Reply With Quote
