Old 11-19-2009, 09:49 AM   #1
Suspended
Default how to remove stripped screws
Hiya,
I just received my used Hyper 8, but many of the underside countersunk hex screw are stripped and wont come out.
Is there a tool to remove them?
Also, the center driveshafts on the car have a lot of movement in them - they can move back and forth a large amount. Is this normal for this car?
Many thanks for any help!
jjl5590 is offline   Reply With Quote
Old 11-19-2009, 09:53 AM   #2
losiracer78's Avatar
Originally Posted by jjl5590 View Post
Hiya,
for the screws you can use a good set of easy outs or a small cutting disk and cut a straight cut in the screw head and use a flathead screwdriver
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 11-19-2009, 10:25 AM   #3
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
Dremel + Cutting Wheel = new flathead screw ;-)
MotoGod is offline   Reply With Quote
Old 11-19-2009, 12:13 PM   #4
Use the correct size drill bit for the head of the screw and just drill the head off the screw.
H9_nutter is offline   Reply With Quote
Old 11-19-2009, 12:39 PM   #5
savage.25's Avatar
Send a message via MSN to savage.25
yup what others have said about the screws
also there shouldnt be a lot of "play" in your driveshafts.. replace the cups. you can buy them in a set of 2 i believe from your LHS
savage.25 is offline   Reply With Quote
Old 11-19-2009, 02:25 PM   #6
fatdaddy's Avatar
I use these and swear by them. they have saved me and other people around the track countless times
http://www.amazon.com/Alden-8430P-GR.../dp/B000H6PM32
i use them in my little ryobi drill that i use on my car normally. they run in reverse. one side drills out a small hole, and the other side has reverse spiral with notches in it that locks in and grabs the screw.
i can get almost anything with these. from the tiny set screws in CVD's to the large motor mount bolts.
before you get out the dremel and start cutting up your chassis, try these out first. you wont be disapointed. i linked them to amazon, but i think you can get these pretty much anywhere. i got mine at Lowes.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 11-19-2009, 02:30 PM   #7
Trader Rating: 21 (100%+)
Instead of tossing your dremel cutoff wheels when they get small, save them for slotting stripped screws! One about the size of a dime will not mark the chassis and lets you cut deep enough to get it with a screwdriver.
Duster_360 is offline   Reply With Quote
Old 11-19-2009, 03:38 PM   #8
Torian4000's Avatar
Trader Rating: 49 (100%+)
Hiya,
I ran Ofna for 7 years and raced the Hyper 8 and Hyper 8.5. They do have quite a bit of play on the center dog bones! No worries, it won't affect the performance at all. You can replace them but it won't do much good.
Torian4000 is offline   Reply With Quote
Old 11-19-2009, 05:37 PM   #9
Kalgard Racing's Avatar
PRO GRABIT!!! SO FOOKING EASY AND NEVER CUT ON A CHASSIS AGAIN.
Kalgard Racing is offline   Reply With Quote
Old 11-19-2009, 10:57 PM   #10
shanty140's Avatar
I use these and they work awesome. Gets the screws out in very little time.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 11-20-2009, 12:14 AM   #11
speedy2's Avatar
on screws metal to metal
I found out heating the screwshead
with a hot solderingbit for 1 minute loosens up locktight
(you hear it starting to cook with little sqeeks )
and than you can often get the screws to loosen using a new Allenbit
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 11-20-2009, 03:15 AM   #12
Suspended
the thing about the screws, i think the previous owner might have used red loctite on them, because i was breaking my allen keys trying to get them out
Old 11-20-2009, 05:15 AM   #13
On stripped hex screws i use star/torq bit to remove them, or the hammer a next size up method.
best of luck.
kevinl7778 is offline   Reply With Quote
Old 11-20-2009, 09:07 AM   #14
fatdaddy's Avatar
like speedy said. hit it with a soldering iron, or a heat gun till its loosens up
