Old 11-17-2009, 01:50 PM   #1
Default Ceramic vrs Stock bearings???
Hello,
I have a MBX5R. Just wondering, is there is a big advantage getting the ceramic bearing kit over the stock bearings??
Do they last longer etc?? Any info will help, thanks
Kevin.
Kevin.R is offline   Reply With Quote
Old 11-17-2009, 02:16 PM   #2
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Kevin.R View Post
Hello,
Kevin.
I would not say it is a big advantage, but they will probably last longer. They are actually unnecessary in my opinion.
Now ceramic bearings in the motor is a different story, I highly recommend them in the motor. The motor spins a whole lot more revoluitons than the drive train. At least 14 times as many on most buggies and 16 times those on a truggy.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 11-17-2009, 02:31 PM   #3
fatdaddy's Avatar
in the motor. definately
everywhere else in the car, just standard yellow seal Avids. they get dirty too quickly so ceramics are just a waste of money imo
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 11-17-2009, 06:27 PM   #4
fast11970's Avatar
I am leery about a ceramic front, those seems not to seal until the engine comes up to temp, so you are runnin lean for awhile, I know I had one in a quality mill, it ran warm and leaked until the temps got up to normal, the rear bearing seems to be a big help, I went back to stock on the front. I will run Ceramic Clutch bearings, for a long main 45min-1hr, I have run them on the C-diff and on the inner ones in the front/rear diff, it seems to let it spin with less resistance, I dont run em on the out drives or the wheel ends...they do get to dirty, IMO...
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 11-17-2009, 07:04 PM   #5
Zerodefect's Avatar
Yup, ceramic rear bearing in the engine. Standard NR or RB up front. Avid Revolutions on the chassis.
Usually my cars bearings get killed by grit and dirt getting past the seals. My bearings would last a year if they stayed clean. No point in useing ceramic on the chassis.
Zerodefect is offline   Reply With Quote
Old 11-17-2009, 07:40 PM   #6
burnettk's Avatar
you can take avid bearings, and pop the seals off clean the grease out and put 2 drops of trinity bearng oil in them and they will spin freely like ceramics, and last longer than those with grease because they build less heat.
burnettk is offline   Reply With Quote
Old 11-17-2009, 09:39 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
Ceramic bearings and dirt do not mix. I would not waste me time with ceramic bearings in an offroad car. Like said above I would only use ceramic bearings in the engine/ and +1 on the avid revolutions, rubber seal to the dirt side and metal shield in.
Old 11-17-2009, 09:57 PM   #8
tc5 man's Avatar
yea i dont know about doing that espially in 1/8 nitro buggy electric i have done that ,i think putting ceramic bearings on the diffs arent bad i havnt had to much dirt at all on those bearings , and espially if u put a thin line greese around the diff case
Old 11-18-2009, 12:27 AM   #9
mblgjr's Avatar
Trader Rating: 86 (100%+)
I've run the premium Acer ceramics in 3-diff chassis now. I won't be doing it again.
Quality steel bearings spin just as free if you use a thin lube in them and they actually last a little longer.
Ceramics + abrupt impacts + dirt don't mix.
The only way they will live is if you service/clean them every other race weekend basically. Cost vs. Return is too small...put your money elsewhere.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-18-2009, 04:58 AM   #10
Thanks for the info guys!
Kevin
Old 11-18-2009, 06:57 AM   #11
cary's Avatar
Trader Rating: 67 (100%+)
ceramics are just that a waste of money and time been there
done that Avid Revolutions all the way at a buck each no more
wasted time cleaning just put a fresh ones in and your good to go
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 11-18-2009, 01:07 PM   #12
Madbrad's Avatar
Trader Rating: 29 (100%+)
I never clean my bearing either, for a $1 each it easier to just toss and put in a new one.
Does any one use ceramic on your clutch ? I was thinking about that, but still have a lot of standards to use up first.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 11-18-2009, 01:11 PM   #13
tc5 man's Avatar
i use a ceramic inside of the clutch bell and use a high rpm bearing in the front of the bell its a tko and they are allsome
Old 11-18-2009, 01:29 PM   #14
blktransam's Avatar
Trader Rating: 59 (100%+)
avid 1.00 each....run them in my clutch bell with zero issues...I change them out every race day a whole 2.00 lol...soetime I get lazy and go 2 race days on them could go longer but no need to chance it for 2.00....
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
