Old 11-15-2009, 10:23 PM   #1
Trader Rating: 20 (100%+)
Default axe rossie mamba with nova carb??
is it doable? i think my stock metal mamba carb is acting up that either cant hold tune or air leak. i think the nova plastic may save my day..Tx..
xxx123 is offline   Reply With Quote
Old 11-15-2009, 10:27 PM   #2
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
I dont know about the nova carb but could you tell some symptoms of the axe carb I have the Axe mamabe evo X1 and maybe able to help
kodiakbear7070 is offline   Reply With Quote
Old 11-15-2009, 10:36 PM   #3
just cant idle...sounds like overheating....cant hold tune...all kinds of trouble that you dont want to happen...
Old 11-15-2009, 10:43 PM   #4
1st did physicaly pull the carb out and seal there and also the carb vent. and did you check the needels to see if the o rings where crack and distorted in any way both high needle and your low needel
2nd what is your temp on your motor?
3rd have you went back to the factory setting witch is very very rich and if you dont have I can get those for you
