Old 11-18-2009, 07:49 AM   #31
rider313's Avatar
Trader Rating: 94 (100%+)
so a well ballanced wheel will just come to a random stop, IE. not the sane spot if you do it over and over?
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 11-18-2009, 07:54 AM   #32
Integra's Avatar
yes sir.
actually you should be able to stop it at 12 3 6 and 9 and it should NOT move from there......you can even go 1/2's in between 12 3 6 and 9 to ensure its balanced properly.
Old 11-18-2009, 10:27 AM   #33
rider313's Avatar
I found this vid. I think its better than the other one.
http://www.youtube.com/watch?v=mPre2...eature=related
Dan Williams
MNRC Chairman
Old 11-18-2009, 01:45 PM   #34
Integra's Avatar
1/2" offset and putty is imo wrong.
also the fact all he's done is create a heavy side opposite of the initial heavy side which is also wrong if you ask me.
Old 11-18-2009, 02:00 PM   #35
rider313's Avatar
haha there is more to this than i originaly thought?
Dan Williams
MNRC Chairman
Old 11-18-2009, 02:14 PM   #36
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Tire balancing takes a lot of patience but forced if I buy anything but AKA not perfect but decent. The dubro unit is awesome very sensitive. Having your wheels / tires stop in random spots is a science would rather pay someone too take away this frustration. All the youtube instructional video are not for the extreme RC enthusiast its basic but a good point would be foam seating and glue job will affect balance .NEW foams from Proline are awesome.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 11-18-2009, 02:35 PM   #37
rider313's Avatar
the dubro balancer says you need a part for it to work with off road tires? what is this part?
Dan Williams
MNRC Chairman
Old 11-18-2009, 05:38 PM   #38
motomatt's Avatar
You can use a wheel hex and nut instead of the piece Dubro suggests.
motomatt is offline   Reply With Quote
Old 11-18-2009, 06:17 PM   #39
Integra's Avatar
X2 a simple 17mm wheel hex and nut and some fuel tubing and rig it up......i keep 1 side of the tubing real short for easy removal and keep the long side and the height gauge pending if im doing buggy or truggy wheels.
Old 11-18-2009, 06:34 PM   #40
rc skyline's Avatar
X 3
You guys are spot on.. I too use the fuel tubing technuiqe and fit a wheel nut in the wheel and put the cone shaped bits pointy side to none pointy side if that makes sense?
You simply do not need the extra peice if you use your noggin
Plus it makes the dubro balancer a real bargian
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 11-18-2009, 06:48 PM   #41
Ronregas's Avatar
Default Better traction and saves bearings...
Ballencing your wheels makes for better traction. You will see realy bad unballenced wheels bounce up and down up the straights and put heaps more stress on the bearings. Ballence them and you will notice the difference for sure. A good ballenced wheel when done right will spin longer, then stop in random spots everytime. 90% of all wheels I have got new have had to be ballenced. I use modelling clay or plastasine, they both work fine and are cheap and easy to get. Once you do it once you will be hooked.
Ronregas is offline   Reply With Quote
Old 11-19-2009, 07:20 AM   #42
Mack_Mechanic's Avatar
Anyone run their new tires for a few laps to "run in" the inserts before balancing?I don't know if it helps but it makes me feel better(in my head at least,lol) about the balance of my tires if the inserts have been "run in".
Steve Arms
www.rcracebarn.net
There is no such thing as too much motor....just not enough driver!
Mack_Mechanic is offline   Reply With Quote
Old 11-19-2009, 03:17 PM   #43
Integra's Avatar
another BIG part of what both vids posted lacked....doing this is a MUST as the foams will move a bit when they are brand new.
I run them for a quali and call em good....or if there buggy tires i take them for a rip on my E in the front yard.
Old 11-19-2009, 03:41 PM   #44
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Racecrafter View Post
The main thing is how he says "When the 0 degree mark reaches the 90 degree mark that now it's balanced" No... Now his 90 degree mark is the heavy spot.
A well balanced wheel/tire will have a hard time finding a place to rest.
As a matter of fact my wife just bought me a digital video camera and we will start to make videos. One of them on the list is how to properly balance tires.
What do you guys think causes 'a new heavy spot' when in the process of balancing?
cpaurl
rallyebmx is offline   Reply With Quote
Old 11-19-2009, 05:13 PM   #45
Integra's Avatar
having the weight Off the mark.....if the tire's out A Lot you have to Spread the weight out to get the tire to balance out.
