Old 11-14-2009, 10:51 AM   #1
Thumbs up GotNitroOnline Introduces the VRX-2 Pro Buggy
Hello everyone just want to take a minute to introduce our new 1/8 scale buggy. For more information and video please check out our site at www.gotnitroonline.com. We welcome any questions or suggestions.
You cannot go wrong with this top notch 1/8 scale buggy at a great price. Please check out our website for special introductory pricing on these RTR buggies and more!!
Comes with 2.4GHz radio system. All machined steel drive train, powerful 4 disc brake system. Front universal joints not dogbones. Billet shock towers not plastic. Here's what comes with the Ready To Run Pro version;
*Carbon Fiber Center Diff Upper Plate
*Carbon Fiber Steering upper Plate.
*Carbon fiber Radio Tray.
*Billet Rear shock Tower
*Billet Front shock Tower
*Billet Front Chassis Brace
*Billet Rear Chassis Brace
*Front and Rear Steel suspension plate hinge pin mount for extra strength.
Easy access suspension provides quick multi-angle changes to permit the vehicle to perform on any racing surface. Comes complete with 2.4GHz digital 3 channel radio and high end servos installed. Nice well balanced tons of adjustments 2.4GHz transmitter and receiver. Very cool Blue LED menus with easy access adjustments at your finger tips. Easy access camber adjustment through specially designed rims. Powerful Four disc brake system Top quality shock protection performance Machined steel gears and Solid Differentials gears Three Differentials and four wheel drive system Front universal joint and fully ball bearings Solid 6061 T6 anodized soild aluminium chassis Lightweight engine, flywheel with solid universal joint cup Good quality wheel rims and Cube-nailed tread tires provides a long service racing period. High foam element air filter sponge Front and rear metal sway bars Leak proof 125cc fuel tank with the long overflowed pipe. Oil filled shock absorbers Painted and pre-cut blue, black and white polycarbonate body for high impact protection. Powerful Engine: GO. 21 CNC-cut alum. Shock towers/front and rear brace and Carbon Fiber Upper/radio plates. Overall Length.....................505mm Overall Width.......................305mm Height...................................175mm
Wheelbase............................330mm
Front Wheel Track................258mm
Rear Wheel Track.................261mm
Gear Ratio............................ 1:11.85
Wheel Diameter....................115mm
Wheel Width...........................42mm
Ground Clearance...................35mm
Weight................................... 3.5 kgs
Standard VRX-2 Features: Alloy chassis with pivot ball suspension. Big block .21 pullstart GO Nitro engine installed. Front universal drive shafts - not dog bones. Alloy front and rear shock towers - not plastic. Quad disk brakes - Yes 4 disks on the center diff out shafts - see pictures. Alloy tuned Chrome exhaust pipe tuned to the GO engine - not plastic. Steel pinion AND SPUR gears - full metal diff gears and drive train. Alloy big bore shocks. The new GO brand engine is being used in races all around the world. Top quality rubber and rims. This is a top quality race ready 1/8 scale buggy. Front Pivot Ball Suspension Front and Rear Sway Bars Front Universal Drive shafts Sealed Bevel Gear Diffs Big Bore Racing Shocks Complete Ball Bearings Super Powerful .21 Pull Start GO Nitro Engine 46 Tooth Steel Spur Gear Low CG Radio Tray Fully Adjustable Suspension 3 Shoe Aluminum Clutch 125cc Fuel Tank with filter High torque Steering Servo Spiral cut Steel Conical Gears Heavy Duty Suspension Arms Lexan Painted and cut out body. Incrediable speed and performanace right out of the box! Alumimum and carbon fiber construction. If you are looking for a 1/8th nitro buggy that you can race successfully at the highest level without any modifications then this is the perfect choice. This is a VRX-2, crammed with all the upgrades to make it a race winner. It is one of the highest spec buggies on the market but at half the price of similar models! It is one of the highest spec buggies on the market but at half the price of similar models! You want proformance, reliability and durability? Check out GNO's VRX-2. On-Sale: Nitro Powered 1/8 Scale 4 Wheel Drive Ready To Run Buggy PRO version with GO .21 Nitro Engine with 3 channel 2.4GHz radio installed. Incrediable speed and performance right out of the box!
Gotnitro2 is offline   Reply With Quote
