Old 11-12-2009, 12:01 PM   #1
Suspended
Default Which truggy should I get?
Heya,
I'm looking to buy a truggy roller to make electric. So far, the only ones I've looked at and am able to buy are:
Hong Nor/Jammin/Ofta X1 CRT - 90
and
Hot Bodies Lightning Stadium 2 Pro - 100
I've already been told that RC-Monster has the parts to convert the HBLS to brushless, but i'm not sure about the CRT.
I plan on running the MMM 2200 combo on 6s in there - I don't race, only bash, and i'd like to try and achieve 70+mph with speed runs.
Has anyone had any experience with either of these two truggies?
Many thanks for any advice given!
jjl5590 is offline   Reply With Quote
Old 11-14-2009, 02:27 PM   #2
vnmsgt's Avatar
Take a look at the Caster Racing F8T Race Roller. You don't have to convert anything. Its setup electric for you already. There is even a RTR and PRO KIT version available.
http://holeshothobbies.com/index.php...roducts_id=480
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 11-16-2009, 07:43 AM   #3
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
What he said. It may actually be cheaper than a used truck + conversion stuff... and the Caster stuff is underrated. They are "ground up" electric designs, not a thrown together conversion- VERY nicely engineered.
However, back to your question. I used to run the Jammin. Good, tough truck, outdated compared to newer designs, but still a solid truck. It won't turn with the newer ones, and uses an enormous spur gear with buggy gearing in the front and rear... that raises the CG slightly.
I have no experience with the HB but I've heard pretty good things about it. I would probably pick the HB between those 2.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-16-2009, 10:59 AM   #4
wallot's Avatar
caster design is nothing that great. split packs do not allow balanced car as motor on on side is 10+oz (almost 14 in case of tekin t8)
battery weight at the rear hampers steering
rc-monster has motor mounts for probably all standard cars as well battery mounts
rc-monster parts make very well balanced car
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 11-16-2009, 11:10 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
If you are going electric than there are a couple of MFG's out there that will accommodate any truck that you get. Tekno is one. As for the truggys I currently like 3. Losi 8t 2.0, Mugen mbx6t and AE rc8T. These trucks perform very well at the track and are always in the winners circle at the main stream events. Stick with what works.
Old 11-16-2009, 01:56 PM   #6
Suspended
sorry guy's ive already bought a hyper 8 roller.
What BL combo should i get?? Krazy Electric Off-Road 11 09-24-2009 01:28 PM
What Should I Get alilchubz Rookie Zone 12 04-11-2009 11:10 PM
Which one of these 2 r/c's should i get? Zeeshan Rookie Zone 36 03-17-2009 09:08 PM
What starter box should I get? HWYSHREDDER78 Nitro Off-Road 9 04-19-2008 09:37 PM
what truggy should i get? busta774 Nitro Off-Road 19 02-26-2008 06:40 PM
