Old 11-11-2009, 05:02 PM   #1
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Hitec coreless servo
Hi, i am new on coreless digital servo. May I know what the different between coreless digital and digital servo? I do owned few digital servo and I can hear clicking sound when i try to put some load on it but this coreless servo the clicking look noisy then my digital servo, is that normal for a coreless servo act like this?? Thanks.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 11-11-2009, 05:08 PM   #2
tc5 man's Avatar
i have a diginal futaba servo thats cordless the diffrence i notice is they are smoother and a bit faster maybe and center pretty good ,my doesnt make a clinking sound it just buzzes
tc5 man is online now   Reply With Quote
Old 11-11-2009, 05:40 PM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Man theres that cordless servo again. I gotta get me one of these.
Old 11-11-2009, 05:54 PM   #4
tkhoo's Avatar
opppp!!!! I should said buzzes sound Ok, is this buzzes sound keep buzz is normal? I feel it keep buzz then a digital servo....
Better then normal digital servo? How was the power comsuption between cordless and normal digital?
Old 11-11-2009, 05:57 PM   #5
Frank L's Avatar
You guys are cracking me up... I cant take it anymore... Its coreless not cordless. And I have no idea what the hell the difference is. I run the hitec 7950 & 7940 on a 2s lipo and they seem to last about 1 hour to 1:30.
Old 11-11-2009, 05:59 PM   #6
tc5 man's Avatar
its a cordless motor in the servo thats what futaba says aleast
as for the buzzing noise its normal but it should stop after 1sec or so but its fine , as for power compusion it doesnt seem to bad actually maybe cause it has a cordless motor it has less residence
Old 11-11-2009, 06:21 PM   #7
tkhoo's Avatar
Hahahaha.....Hitec show coreless.
my is keep buzz, i put it on throttle and maybe the resistance that keep pushing the carb close that casue keep buzzing, what you think?
Old 11-11-2009, 06:27 PM   #8
tc5 man's Avatar
do u have a small gap on the throttle linkage where the collar is at
my does it when im at netual but soon as i push the trottle spring back it stops i just have to take a other coil off then it shuld stop
Old 11-11-2009, 06:43 PM   #9
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
Coreless refers to the rotor or winding type. The rotor in non-coreless uses copper or steel whereas a coreless (or ironless) motor can use aluminum or lighter mass material. Coreless motors are faster and more efficient (from less friction or cogging) but draw more power and run hotter.
I had to look this up.
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Old 11-11-2009, 06:44 PM   #10
Zerodefect's Avatar
Take a 27t stock motor, look inside. See how the windings are attached to a steel armature made up of stacked steel plates called a lamination stack.
Coreless motors don't have that. They use a basket weave of wire that deosn't need support the way standard winds do. So they are lighter and have less rotational inertia giving them faster response.
At least thats what it looked like to me on the motors I've seen. (not servos though)
Just stick to Hitecs 7955, 7950, 7940 and you don't have to think about these things anymore.
You could call a brushless servo motor cordless. It has no cords or bushes contacting its rotor........
Ready dis to exorcise ye brain:
http://www.electricmotors.machinedes.../bdeee3_2.aspx
Zerodefect is offline   Reply With Quote
Old 11-11-2009, 06:45 PM   #11
fatdaddy's Avatar
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 11-11-2009, 06:47 PM   #12
tkhoo's Avatar
you mean collar is the one at the front on the linkage where servo horn push it to make the carb open? If yes, then I do not set it a little gap. Also i think when my throttle in neutral position the throttle return spring give the servo a load and the servo keep buzz is because it keep looking for center?
by the way, if a servo is looking for center and we prevent it to center like on throttle do it able to kill the servo?
Old 11-11-2009, 06:57 PM   #13
tc5 man's Avatar
the servo should center when u let of the throttle ,not sure if you dont let it center when your throttle it will kill it but u do what a gap inbeween the collar and the spring.your spring might be to stiff i wouldcheck that that will put a load on the servo
Old 11-11-2009, 07:06 PM   #14
tkhoo's Avatar
Ok....I wll try to make the servo as less load as I can. I might try to cut off some of the spring. Thanks.
Old 11-11-2009, 07:09 PM   #15
tc5 man's Avatar
one spring at a time though and test it out everytime not to much cause itwill be too soft
New Hitec 5965 Digital coreless servo for sale C.Capelo R/C Items: For Sale/Trade 9 07-19-2008 10:08 PM
