Old 11-11-2009, 07:19 PM   #16
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Originally Posted by tc5 man View Post
one spring at a time though and test it out everytime not to much cause itwill be too soft
Noted
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 11-12-2009, 01:25 AM   #17
Gizmatron's Avatar
Send a message via Skype™ to Gizmatron
+1 on that digital servos buzz if they are under load...flick your accelerator towards brake a fraction and it will probably stop buzzing as it self centres.. but yes if your throttle spring is too stiff it will buzz and yes if you leave it like this for ages the motor will eventually heat up and possibly die..how fast this happens depends on how high the torque of your servo is (higher torque=lower gearing = less strain on the motor) and how over stiff the spring is..if flicking the servo in the opposite direction doesn't centre it and stop the buzzing then you can either shorten the current spring or look for one with thinner wire ..ie a softer spring...if you use a softer spring it will most likely have closer windings so make sure at full brake it doesn't become solid and push your carb..
this said when driving your throttle/brake servo is pretty much in motion the whole time so this is not an issue but personally as part of my build quality I would consider this a poor setup.maybe I'm just too anal/nerdy
2009 808 - Tekin RX8 1400/6S 1700/1900/4S rcmonster custom chassis
2012 XB9 - MG66 R7 godzilla from maaaaaaassive with alpha 2090 pipe
Futaba 3PKS with spektrum pro module and RX
hitec HS5955tg and HS7965tg servos
Gizmatron is offline   Reply With Quote
New Hitec 5965 Digital coreless servo for sale C.Capelo R/C Items: For Sale/Trade 9 07-19-2008 10:08 PM
