Old 11-11-2009, 11:07 AM   #1
Default After run oil.
If i run my truck once every night do i still need aafter run oil in it at the end of the night, i'm a noob, thanks for the help
kevinl7778 is offline   Reply With Quote
Old 11-11-2009, 11:10 AM   #2
Cory Kerber's Avatar
If you run every night, there's no need to apply ARO, especially if you're running a quality fuel like Byron's; Sidewinder; Odonnell; Coldfusion. However, if you aren't going to run it for a couple weeks it's a good idea to put a couple drops in.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 11-11-2009, 11:29 AM   #3
Thanks, that makes a bit less work at the end of the night.
1, walk the dog.
2, run the truck.
3, eat dinner.
4, run the truck.
I'm seeing a pattern.
Old 11-11-2009, 11:33 AM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I will use AOR only if my engines are going to sit longer than a week. Otherwise its pretty pointless. If you are running every night then no need to use it. There is enough oil in the fuel to keep the engine free from rust.
after run oil redza Nitro Off-Road 20 02-09-2009 02:55 AM
After run oil? jpolston Monster Trucks 13 08-26-2008 06:20 AM
After run oil/wd40 supermoto552 Nitro On-Road 13 04-07-2007 01:22 AM
after run oil? wcairsoft3r Electric Off-Road 21 01-19-2007 09:25 PM
After Run Oil? DookieBooty Nitro On-Road 61 01-31-2005 10:07 PM
