Old 11-10-2009, 11:26 PM   #1
Default HEADER PIPES!?
I got a 2050 pipe but no header so I put a Orion 2066 header on it and to me it just doesn't seem to have the bottom of the 2035 I ran before and the top doesn't seem to be there either. My question is do u think because the header is short that maybe my problems is this and I should put a longer header on? The pipe is the right pipe for this engine lol
jeff alessi 801 is offline   Reply With Quote
Old 11-11-2009, 04:24 AM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
short header will give high top end and long header will give more bottom end torque. its kind of your choice once you have the pipe your engine likes
8&stuff is offline   Reply With Quote
Old 11-11-2009, 08:15 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Diff engines like different pipe/ header combos. When I ran grp engines I always used a rb long header on a dyn 053 pipe to get the best performance out of the engine I could. When I started running speed engines the 2060 pipe/ header worked better than the 053 pipe and before I had the 2060 I ran the speed with the 053 and a med header. The long choked the top end and the short killed the bottom. Every engine is different so it's up to you where you think they perform best. +1 on the Long header increases bottom and the short increases top end. Btw what engine are you running?
Old 11-11-2009, 09:44 AM   #4
Ok so I guess I'll be trying a longer header next to see if it makes it better.
New plus 4's, pipes, and other good stuff. jpz_67 R/C Items: For Sale/Trade 36 05-03-2009 04:59 PM
1/8 scale offroad pipes, a discussion Cain Electric Off-Road 24 03-21-2007 11:51 AM
